Results 1 to 9 of 9
Thread: Heavy steering - 99 VT Calais
    VT Calais
    Aug 2011
    Surfers Paradise
    Default Heavy steering - 99 VT Calais
    Hi...
    I have a 99 VT Calais. A couple of times lately, my steering has become quite heavy. It seems to fix itself pretty quick (a few minutes) when I get going but obviously there is a problem there somewhere. I have a slight leak in the steering pump but fluid levels are fine. Is it likely to be the pump, and does anyone know how much I should be paying for this to be fixed?
    Cheers.
    1989 vn white
    Jul 2011
    Warranwood, Melbourne
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by dannyboy88 View Post
    Hi...
    Cheers.
    I had that happen a few times a few years ago, it would fix itself after restarting the car. The problem went away for good on it's own.
    MY RIDE
    GAMBLR's Avatar
    GAMBLR is offline More trouble than u think
    '04 VZ Calais LS1
    Dec 2006
    Whyalla (yawn), South Australia
    The Calais has speed sensitive steering, so that unit might have a fault. I don't know much about it (whether it's a mechanical or electrical unit, how it works, etc.) but that might be the cause.
    Basically, it makes steering at certain speeds lighter/heavier to help keep the car straight and make slow speed manouvering easier.
    CruznCalais
    [GAMBLR]
    The VZ is here! About time!
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    about 300$ for a new pump and fitted mate.
    it sounds like the pump. if it works when you get going.
    Starin at the world through my rearview
    Go on baby scream to God, he can't hear you
    I can feel your heart beatin fast cause it's time to die
    Gettin high, watchin time fly
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    Possible your pumps on the way out.
    Good way to check is too put in N and rev to around 1500 no more is needed, then whilst holding the revs turn the wheel - if it's lighter I'd bet it's the pump is forked. Can also be accompanied by a whine.
    The New Ride - The Class 2 Shuttle Craft (VE)
    I'll be he comes to get you, some shopping trolley kind of thing, that gets you where your going nice and slow... Well off you go that's fine, the pleasure's all mine.
    When I light the nitro on my HQ 454 Monroe!
    VX Calais LS1, VS Calais L36
    Mar 2010
    The speed sensitive steering in the Calais has a solenoid in the rack, controlled by the BCM. If the fault is off or on, and when it's working it works fine, my money's on the solenoid. I've heard stories of heat from the exhaust damaging the wiring, so I'd start by checking the wiring to the solenoid.
    VT Calais
    Mar 2009
    SA - Victor Harbor
    mine used to do it, was just the solenoid its cheap and takes less then 30min to fix
    Mar 2010
    I didn't realise the solenoid was serviceable, lufkin. IIRC, the manual says it isn't, go get the rack reco'd,
  1. very heavy steering
    By race4life in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-02-2012, 12:01 PM
  2. Vt Calais heavy steering
    By stumpy03 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-05-2011, 08:30 PM
  3. Heavy steering in a VT
    By savage1987 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-11-2009, 06:21 PM
  4. Heavy steering
    By thehsvmanv6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-03-2007, 10:06 PM
  5. Heavy Steering.
    By ICUBYE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-08-2006, 04:35 PM
Tags for this Thread
