Results 1 to 18 of 18
Thread: replaced key battery
    Holden vt calais 5 litre
    Nov 2007
    Default replaced key battery
    just replaced the battery on my spare car key and the key-less entry does not work is there a way to check if the key is transmitting at all? does it need to be in its key-shell to work? i did leave the old battery out for about two days
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Sorry buddy, once you took the old battery out the key lost the codes to unlock the car. Bin it and buy a new one.
    Ronald Reagan (1986)
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    yes there is some kind of time limit to swap the battery i read somewhere it was like 10 seconds before it loses the codes. Holden are sneaky thats for sure.
    ========My Statesman 20's Mafless and 3.9's========
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    VX Berlina S1
    Nov 2009
    What size/type of battery do they use? I have a Series VX Berlina that needs a new battery too.
    Cheers!
    VX Berlina
    Apr 2007
    Its not easy to swap the batteries in these things, not impossible just very, very hard. For starters you cannot let it go without power for even a second, or you risk it losing the code. Second, the battery is spot welded in, good luck. Third, you will need to be able to weld the new battery in without making it explode or leak.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Also, getting the shell apart without making a mess is not easy. Holden do their very best to discourage battery replacement. They won't to rip you off with a new remote.
    MY RIDE
    Commodore M6
    Jul 2010
    East Coast
    to be fair everyone does a similar thing
    most companies solder in a battery so they don't have to deal with issues arising from that
    Nov 2007
    1.Turn the ignition to ON, then wait 10 minutes for the next step in the programming sequence.
    2.After the 10 minutes has elapsed, the car horn will chirp once. Turn the ignition switch to the OFF position within 5 minutes after the horn has sounded, then to the ON position within 5 seconds after switching it OFF.
    3.Leave the key to the ON position for 10 minutes. After the 10 minutes has elapsed, the car horn will chirp twice. Turn the ignition switch to the OFF position within 5 minutes after the horn has sounded, then to the ON position within 5 seconds after switching it OFF.
    4.Leave the key to the ON position for 10 minutes. After the 10 minutes has elapsed, the car horn will chirp 3 times.
    5.Verify that the security indicator in the instrument cluster has stopped flashing and attempt to start the vehicle.
    6.Turn the ignition to OFF and remove the key from the ignition switch.
    7.Move approximately 3 meters (10 ft) away from the vehicle and test the transmitter functions to validate that the transmitter has been programmed successfully.
    has anyone done this before?
    Commodore M6
    Jul 2010
    East Coast
    hmmmm
    is this the similar thing to what you do with a new key...
    ie. pop the doors open with old key
    start the car with the new key
    and the BCM programs the final part of the new key
    thats what the key cutter dude told me to do
    Dec 2009
    The battery is available from Jay Car with the welded tas on it so you just need to de solder it from the PCB. they only cost a few dollars. If you bugger the shell you can get them off e-bay for about $10.00.
    The key tang is the arial for the transmitter so you have to have that screwed in place so it's electrically connected to the circuit board.
    I was of the belief from what I have read elsewhere here that the key would still start the car if it's battery went flat and the battery was just for the keyless entry part.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    you need a tech2 to reprogram a key fob, the key cutter mr minute guys start the programming from your old key which is then finished buy using it. Keys do not reprogram by themselves, otherwise it would make stealing cars easy.
    vx custom 600RR
    Oct 2010
    Quote Originally Posted by wortus View Post
    when i did mine i stuffed the first battery by over heating it as the solder wouldn't take to it, which i reckon you did
    once programmed you never lose the function same as with aftermarket remotes when you change batteries, don't believe in the bullshit people tell you
    wish i had known they were available when i did mine
    vs commodore
    Oct 2009
    Tamworth NSW
    Ive replaced the batteries a couple of times in my VS keys, which, as far as I know, are exactly the same as VT keys , and I had no battery connected to them for ages whilst I removed the old battery etc, and soldered the new one in, and the remotes still worked fine once they were fitted with new batteries and reassembled so they dont loose their programming ,well at least not in the few hours that I had them apart and disconnected.
    To solder to the battery you need to sit pliers or similar right next to where the tab is being soldered onto the battery, the pliers will act like a heatsink and will soak up some of the heat from the soldered joint on the battery, you also need heaps of soldering flux on the battery to get the solder to stick to the battery quickly so it doesnt have to be heated for too long ,which will stuff the battery, I know, Ive done it before too.....
  15. #15
    VX Calais LS1, VS Calais L36
    Mar 2010
    I've also changed the battery in VS keys. Would have gone minutes without the battery installed, and they work fine.
    I used a new $10 case of ebay and a standard CR2032 battery. I prised the tabs off the old battery and glued them onto the new battery.
  16. #16
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    I havn't had to change batteries yet, though I have had to place some alfoil in and around some of the contact areas within the key head. Are you sure all your contacts are, well, contacting? I did this to both my keys as the bad contact was all that was wrong.
    Prying apart the housing can be tricky, (I ended up with five stitches in the palm of one hand after the knife slipped) but after it's been glued back together carefully and properly, it's hard to tell that the head has been opened.
    When my batteries fail, I will be changing them myself.
    Edit: There is a How-to on the alfoil trick on a VS key.
  17. #17
    VX Executive S2
    May 2006
    Frankston South Vic
    seriously for the cost of a new remote isn't it worth it for the peace of mind
    so many people fit new buttons and new battery and the time involved and possibly stitches, ouch!
    considering the inconvenience when a remote fails just buy a new one and have five years without problems
  18. #18
    Nov 2007
    ok i just got the key working all i did was unlock the car with my other working key then started the car with the non working key now the keyless entry works on the spare key now
  1. [SA] FS: RED ARC Battery Dual Battery Isolator
    By exec24 in forum Parts And Other Items For Sale
    Last Post: 29-12-2010, 09:03 AM
  2. Replies: 3
    Last Post: 26-05-2010, 09:22 PM
  3. Replaced alternator in VP 5 litre but battery light still on
    By MasterOfReality in forum Electrical Wiring / Questions
    Last Post: 23-05-2010, 07:24 PM
  4. battery light with brand new battery
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2010, 09:48 AM
  5. [VIC] Misc parts - gauge, steering wheel, speakers, battery cover, battery box
    By georgeonboost in forum Parts And Other Items For Sale
    Last Post: 06-05-2009, 06:32 PM
