Results 1 to 6 of 6
Thread: no acceleration WTF
    VR Calais
    Mar 2011
    Plumpton
    Default no acceleration WTF
    hey guys just went down to the shop and on the way home my car had sweet F.A acceleration, as i pulled into the drive way the revs dropped way below 1000 down to about 300 n then stalled, it started straight away but ran really rough at 300 rpm still, when i pulled it into drive it would jult like someone was playing with a clutch ( Mines auto tho ) letting it in n out without lettin it stall, no matter how far i put the accelerator down it wouldnt move,it also happened to me the other night driving along the M4 i pulled into the breakdown lane and turned the car off then started it again and it drove fine again
    the check light is lit on my dash but the paper clip trick doesnt work on the GEN3 motors does anyone have any suggestions as to what i can check or where to start looking? i need my car for work
    1993 VR CALAIS 5 SPEED MANUAL,Lowered all around on pedders, 20 inch G8s, Option audio front splits, option audio amps, sound stream subs, pace maker extractors, high flow cat, 2.5inch lukey cat back exhaust
    VE Berlina V6
    Mar 2008
    Wollongong NSW 2526
    Could be going into limp home mode?? If thats the case then it'd be the knock sensors setting it off? Just a suggestion...
    VH SL/E...'09 dual cab 4X4 hilux
    Mar 2011
    roxby downs
    maybe something to do with your stall converter check oil level... check plugs leads ect .... maf sensor and wires... sounds like a tricky one might be worth payin some coin to get a mechanic to plug in and check error codes
    If in doubt......FLOOR IT!!!
    VSII Manta
    Apr 2011
    Erica VIC
    VR Calais
    Mar 2011
    Plumpton
    Local mechanic said try the fuel filter, I'm changing that now as I write this so I'll
    Post up how I go
    VR Calais
    Mar 2011
    Plumpton
    So far so good! The fuel that was coming out was black
  1. acceleration.
    By makeyourmove in forum General
    Last Post: 27-06-2010, 03:24 PM
  2. more acceleration on my vz
    By jjaassee in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-03-2010, 07:59 PM
  3. most acceleration on my vz
    Last Post: 10-03-2010, 09:02 PM
  4. acceleration
    By VSCristian in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-12-2009, 07:14 PM
  5. bad acceleration
    By daniel VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-07-2005, 04:23 PM
