heard a ticking sound from the engine the other day after starting the car again after a long drive (engine still hot) the ticking sound would increase with the engine revs, and as randomly as it came it went away after 5min of driving engine is a holden 5 litre
sounds like a sticky lifter mate, have a llisten to the area around your rocker covers.
easy fix
Dan.
Starin at the world through my rearview
Go on baby scream to God, he can't hear you
I can feel your heart beatin fast cause it's time to die
Gettin high, watchin time fly
+1 to that, I've got a noisy lifter, but my car has done a decent distance. Check your oil levels too, can be a bit louder and more noticeable if your oil is lowish.
The New Ride - The Class 2 Shuttle Craft (VE)
I'll be he comes to get you, some shopping trolley kind of thing, that gets you where your going nice and slow... Well off you go that's fine, the pleasure's all mine.
When I light the nitro on my HQ 454 Monroe!
Just started the engine while cold and its making the ticking sound all the time is it still the lifters whats the best way to fix this?
I would say lifter/s still is the best bet. Did you check your oil level/condition? Is your car due for a service?
i would change the oil anyway and see how you go.
and if the noise still happens id change lifters.
the car just had its inlet manifold resealed and the distributor seal replaced by rapid tune so the oil should be new i just put some oil treatment in to quieten the lifters down i will start the car tomorrow to see if there any improvements
what kind of oil did they use if ya know?
ok just started the car today the ticking noise is still there but go's away after a few min im guessing the oil treatment needs a few days to take effect
Yeah mate, mine does that (it's a 6 though), I'd bet it's a noisy lifter.
its not bad for the engine at all is it?
It's not so much bad for the engine, as an indication of the engine itself, they tend to get louder with age/kms travelled. How many kms have you done on it? Mine's been louder the last 100,000km or when the oil is low, and it's at 453,000km, so I'm not overly worried :P
