Results 1 to 5 of 5
Thread: Caliper bolted to stub axle
    VX SS
    Jun 2005
    Default Caliper bolted to steering knuckle
    Hi all
    When i was changing my struts today i noticed that one of yer caliper bolts was loose due to a stripped thread
    Is the correct terminology for the part the caliper is bolted to the stub axle or knuckle? No one knows what im on about.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    sounds clear enough to me. Is it the bolt that is stuffed or the stub? It's kind of important you fix that one.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    VX SS
    Jun 2005
    Yeah there is a wrecker with one so I'll get it changed over asap. I think its the knuckle part as i tried a different bolt and you can get it a little tight but not enough for the proper torque.
    Might try a local thread repairer as it could be less hassle.
    VX Calais LS1, VS Calais L36
    Mar 2010
    Not sure I'd be comfortable with repaired threads on brake components, but I'm sure there's others here more qualified on that than me that will comment.
    VX SS
    Jun 2005
    I'll grab one off the wreckers I think. Will be cheaper than getting the thread retapped.
  1. VT rear stub axel
    By ss_0195 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-11-2010, 07:30 PM
  2. Diff Stub Axle
    By DAVE89 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-11-2010, 08:57 AM
  3. Wheel bearing doesnt want to fit on the stub axel
    By Philth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-09-2010, 12:36 AM
  4. vp stub axle
    By crossie in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-09-2010, 12:20 AM
  5. VZ antenna change to VE Stub???
    By SHADO in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-05-2010, 11:53 AM
