Results 1 to 2 of 2
Thread: slow cranking speed when engine hot
    Holden vt calais 5 litre
    Nov 2007
    Default slow cranking speed when engine hot
    I'm getting a very slow cranking speed while the engine is hot I have tried swapping the battery for a newer one and cleaning the battery terminals with no luck do I need a new starter motor? or have i missed something?
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    sounds like your starter motor is struggling when hot check your starter cable fit a heat shield common complaint when the starter motor is heat soaked , check your earth cable too clean and tight at the battery and the block
  1. Slow VL 6 cylinder 5 speed
    By doigs8 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-09-2009, 12:45 AM
  2. Slow cranking VT
    By SLAF in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-07-2009, 08:41 AM
  3. Diff clonk at slow speed
    By mrvx2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-05-2009, 10:20 PM
  4. VR Slow cranking
    By CrazyDayz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2007, 11:02 PM
  5. Slow Cranking, hard to start hot.
    By Alspos in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2006, 07:21 PM
