Results 1 to 4 of 4
Thread: vt steering issues..help
    VYSS Crewman/ VX Berlina/ FG XR6T work car
    Jul 2005
    Default vt steering issues..help
    My son recently purchased a cheap S1 VT acclaim. All good except for some confusing steering issues. 1/. Squeaking noise from upper column. Appears to be near plastic shroud but no amount of manipulation will get rid of it. 2/. Steering feels tight. Steering wheel doesn't seem to turn as freely as others I have driven. 3/. Occasionally under acceleration there appears to be some vibration from the front wheels. Feels slightly like a wheel balance issue but I have had that checked.
    There are no fluid leaks and the car tracks well on the road. The brace on the immediate front of the K frame is bent as if it's been used to tow the car at some stage and there was a spare column in the boot. The history of the car isn't known.
    These don't feel like big issues but they are annoying. Any help would be appreciated.
    VS Stato l67
    Mar 2009
    Melb
    Tight steering could be a couple of things. The power steering fluid might need replacing or if its got speed sensitive steering (like in the calais or statos) there could be an issue with that.
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    could be the power steering pump causing the tight steering, chuck the car into neutral and rev it to about 1500-2000rpm and turn the wheel if it becomes more easy under acceleration to steer it could be the steering pump.
    also check your steering rack to see if any of your boots are split and not leaking oil.
    hope some of this helps.
    Starin at the world through my rearview
    Go on baby scream to God, he can't hear you
    I can feel your heart beatin fast cause it's time to die
    Gettin high, watchin time fly
    01 VX Executive Series ll
    Sep 2011
    Bathurst
    Hey i would have to agree with DanLucas definitely check the power steering rack I've had a VS and now a VX and had my steering rack go in both and this sounds similar to the problems with my VS, so I would definitely give it a look.
    A.MILMO
  1. vs steering issues
    By despo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2010, 05:20 AM
  2. Steering shake issues, advice before going to mechanic?
    By mars6484 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-01-2010, 08:43 PM
  3. steering issues
    By bradvt98 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-12-2006, 04:56 PM
  4. Steering issues
    By bsbozzy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-09-2006, 05:47 PM
  5. Steering issues Driving me Crazy!
    By brentasaurous in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-03-2006, 09:05 AM
