Hi Everyone,
Halfway through a gearbox transplant and removing the Torque Converter isn't all that much fun.
99 VT auto (m30)
Is there a tool available to buy in Australia to hold the flex plate / crank so i can remove the Torque Converter (as its ####ed)
I managed to remove one close to the only hole in the flex plate that I managed to jam a long handled screw driver into which restricted its movement.
There is so much talk of "un-doing" the bolts but sadly they just dont fall off...
Any help appreciated
1999 HOLDEN COMMODORE VT 3.8 ECOTEC
BASICALLY STOCK EXCEPT EXHAUST, GO THE NOISE!
http://imageshack.us/photo/my-images/51/img0383oh.jpg
Take out the starter motor and use a screwdriver through that hole.
Or get a mate on the crank bolt (should be 24) to rotate the flexplate around and also hold against the force of undoing the bolts.
Originally Posted by Reaper:
Originally Posted by Jecs:
As above. 24mm socket on the crank bolt in the centre of the harmonic balancer.
Z' Series HSV 297KW 6lt LS2 Conversion For Sale!PM Me For Details
A block of wood cut to fit between the bell housing and the flexplate/flywheel to hold it while undoing and a screw driver or pry bar to rotate the engine .
