Results 1 to 12 of 12
Thread: ABS / Trac on-OFF, Oil, Engine Warning Lights on DASH
    VX-01-SS
    Dec 2008
    Question ABS / Trac on-OFF, Oil, Engine Warning Lights on DASH
    Hi there everyone, I have got a VX SS 2001 Sedan. PROBLEM is firstly ABS warning light comes on then a few seconds later all others (Trac ON/OFF, Engine, Oil - like a bloodly christmas tree lights!) Then after checking all engine stuff - eg, oil,fliuds & belts still same thing. After driving for about 15-20 mins the lights all turn off (back to normal) but then repeat - ABS first, then every other warning comes back on after about another 15 mins. So is there any new information on this problem??? Or is it the ABS module problem and no real fix.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It sounds like a faulty ABS module or a bad connection on the plug.
    MY RIDE
    VT S2 Calais 5.7 A4
    Aug 2005
    ryno_vrx's Avatar
    ryno_vrx is offline Donating Member
    VR HSV enhanced Berlina
    Nov 2008
    Mirani
    same thing happened to my vt ss, brought a reconditioned one from ebay and swapped them around within a hour. problem sorted
    whats the difference between my missus and my blower??
    well they both whine but the blower actually puts out
    VX-01-SS
    Dec 2008
    Thanks everyone.... so is it an easy job that anyone can do or is it a job best for someone with more knowledge?? Will be getting new ABS module with traction soon. Hopefully that will sort the problem out...
    HSV VXII Clubsport R8 Auto
    Oct 2008
    Perth, WA
    Hey buddy, I recently did mine too.. Piece of piss job, you will however need to get yourself a set of torx screwdrivers. Other then that its a walk in the park mate..
    Also if you are unsure of it being your ABS module, as I am sure you already know by now.. While driving around, or when ever it happens an it all lights up like a xmas tree.. Pull over an pop the bonnet (dont turn car off!), and disconnect the power harness to the module.. its black an has a red? slider clip on it, slide the clip far right an itll disconnect.. now put that some where it aint gunna get caught in the engine an go look at your dash.. You should see that only trac off trac low an abs lights are on, nothing else... if the engine light is still on even though the ABS module is disconnected then it is possible its your oil sender pump failing. But from what you just discribed it sounds EXACTLY like a faulty ABS module, it hapens too all of us man..
    And replacing the module is easy, i think its 6 torx screws, and I think the size is 2.5? I can remember but easy fix man... $20 set from Super Cheap an your well on your way..
    Hope this all helps bud
    Oct 2008
    Perth, WA
    Oct 2008
    Perth, WA
    Also after disconnecting the power harness and you have looked at the dash, best to plug it back in before you set off driving again, would hate for it to fall onto your headers or anything.. after clipping it back on the car will likely either be 'magically fixed' for a few seconds or just go back to its normal annoying xmas tree self..
    Another point to remember, while in xmas tree mode when the ABS is failing, no other information other then rpm and speed and head lights is relayed to your dash, your fuel will remain at a constant level to when ever the dash light up last and so will the temp gauge, so keep that in mind if you think your running on fumes or its a farking hot day an your out doing doughies coz your trac control is now perm off.. haha
    enjoy
    VX SS
    Jun 2005
    Just leave it disconnected while you are getting it replaced. Its not long enough to fall on the headers or anything.
    VX-01-SS
    Dec 2008
    Thanks everyone for your responses - has helped me alot.... Now the big question, HOW MUCH DOES A ABS MODULE COST??? spoke to local Holden and they are saying Original is $680 but I am sure a re-cond or non-genuie one is a lot less... Has anyone bought one recently and if so where from? Cheers!!!
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by VX01SS View Post
    There are usually plenty on ebay, some reconditioned.
    Just had a look and there are heaps.
    This guy gives 12 months warranty:HOLDEN GM ABS MODULE VT WITH TRACTION ONE YEAR W/NTY | eBay
    MY RIDE
    VX-01-SS
    Dec 2008
    Sorry guys to bother you all again, but is there a difference between the ABS module (with traction control) for a V8 and a V6 - for the VT-VX models? Just want to make sure what kind I'm getting as there are heaps out there... Cheers, and thanks again for the advice.
  1. dash warning lights
    By Patnnad in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-02-2011, 07:36 PM
  2. ABS, Trac Control and Engine Warning Lights
    By aborchy in forum Electrical Wiring / Questions
    Last Post: 19-12-2007, 09:49 AM
  3. Abs - Tcs Off - Low Trac Warning Lights
    By VIPVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-11-2006, 12:24 AM
  4. Trac Off and Engine Lights come on when air conditioner on
    By seedyrom in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-07-2005, 11:37 PM
  5. Trac Off and Engine Lights come on when air conditioner on (VT)
    Last Post: 30-06-2005, 05:59 AM
Tags for this Thread
