Results 1 to 7 of 7
Thread: VT 3.8 ECU changeover?
    1999 VT V6 Signature
    Jun 2010
    Question VT 3.8 ECU changeover?
    Hiya,
    Just a quick inquiry if change the ecu in the 3.8s wether or not you need a techtool for programming it or can you do a straight swap over and away yOu go?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Should be a straight swap providing that you get one from an automatic if yours is automatic or manual if yours is manual. It must also be from a 3.8.
    MY RIDE
    vs commodore
    Oct 2009
    Tamworth NSW
    Ive heard before that on VT and later models you need to have the ECU and the BCM security codes relinked with a Tech2 scantool if the ECU or BCM is replaced for whatever reason,otherwise the security system wont allow the car to start.
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    vt you have to have a scantool i have done this before the car will not run untill you do a hand shake betwen the ecu and bcm
    vt r8 blown
    Oct 2011
    sydney
    hi mate just put in a new ecu in my vt clubby, how do you do this handshaking you talking bout
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by jobbo05 View Post
    You need a compatible scan tool to do a security link between the BCM and ECU (PCM).
    It means a trip to Holden or mechanic with right equipment and knowledge.
    MY RIDE
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Brett_jjj View Post
    I guess I misunderstood the question because I knew that and have written it on here several times before. My brain mustn't have been in gear.
    MY RIDE
  1. SCA Pedal Changeover
    By CrimsonThunder in forum General
    Last Post: 14-02-2010, 06:21 PM
  2. [SA] Transmission Oil changeover
    By GMHCalais in forum General
    Last Post: 02-02-2010, 06:00 PM
  3. PCM Changeover
    By wadevzss in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-11-2009, 03:49 PM
  4. VZ Auto Changeover
    By VZ-Rob in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-08-2009, 10:22 PM
  5. VP to VR changeover
    By discostuee in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-03-2009, 09:30 AM
