Results 1 to 7 of 7
Thread: vt valley gasket question
    VY 03
    Aug 2005
    Default vt valley gasket question
    Hey guys I just wanted to verify that if there is coolant in the oil and oil in the coolant that it is the valley gaskets ? Someone has said head gasket or trans cooler. Not sure where they got that from because the creamy oil under the radiator cap is not pinkish And when i removed the engine cover i could see oil with a small amount of coolant in it laying between this gasket and some has run down onto the valley and down the back of the engine like usual. Any symptoms to say it could be head gasket car has done 210,000 and does have a rough start for about 2 seconds then is fine but this could be anything..
    Thanks
    vr commo
    Aug 2011
    places
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Compression test should tell you if its a head gasket, most likely intake manifold gasket (you need to remove it to get the heads off anyway). replace with some metal gaskets. Last I heard Holden are stocking these anyway.
    Power is measured in DECIBEL
    VY 03
    Aug 2005
    Never did see any noticeable white smoke. I did take the car for a drive about a week ago and it seemed fine beside lifter noise as someone put 10w 60 oil in it So i went to change it to then find this problem. I did take a close look to see if they had ever been changed and i couldn't see anything. I might aswell go ahead with the job as I am just about ready to unbolt the manifold. The car is not mine will try and get pics
    VX 'S' S1
    Apr 2005
    South East,Victoria
    The bolts on the intake manifold do come loose over time . See if you can squeeze a spaner in check them . If they are loose then it will be the intake manifold.
    Changed mine around the 200,000 kay mark .
    VY 03
    Aug 2005
    I did check the bolts as i had that problem with my car Got it off tonight to find the gasket very brittle around the water galleries? So im 100% sure its the gaskets.
  1. V6 valley cover gasket
    By rodeb in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-10-2011, 08:26 PM
  2. valley cover gasket
    By mick_VTSS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-01-2010, 12:01 AM
  3. Valley cover gasket/headgasket
    By AttaBoy in forum General
    Last Post: 15-02-2009, 03:02 PM
  4. Valley cover gasket!!
    Last Post: 17-06-2008, 09:41 PM
  5. Valley cover gasket
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-11-2006, 03:55 PM
