Results 1 to 4 of 4
Thread: HSV XU6 coolant type?
    '98 VT HSV XU6
    Sep 2011
    Tarneit, Melbourne
    Default HSV XU6 coolant type?
    Hey guys I was just wondering if anyone has any info on what type of coolant to use in an L67 I've heard they use a special type of coolant because they run hotter than other engines is this true? Any info would be appreciated as I will be flushing the cooling system and replacing the coolant as well as doing my engine mounts and tie rod ends this weekend.
    VS Stato l67
    Mar 2009
    Melb
    They do run a bit hotter than the standard V6 but I don't think they need any special coolant. In my supercharged 6 I've always just run nulon coolant and it stays very clean and doesn't get rusty or sludgy. Just in case you haven't done it before, make sure you bleed the cooling system properly when you replace the coolant. There are 3 bleeder screws that need to be done in the right order and I usually repeat the process several times to get all the air out. Its been covered a fair bit on here, l67torque and SC forum so do a search around if you haven't done it before
    '98 VT HSV XU6
    Sep 2011
    Tarneit, Melbourne
    Thanks for the info I have bled the system before as it had an air bubble in the system when I bought the car but thanks anyway
    VS Stato l67
    Mar 2009
    Melb
    I had a radiator hose split when I first got mine (bout 4 years ago now) and I just filled up the rad after replacing it and didn't bleed it. It didnt keep proper temperature and I had no idea why.... Such a rookie error
LinkBacks (?)
  1. 03-01-2012, 01:33 PM
  1. Brown sludge in coolant reservoir + coolant level dropping
    By phuecn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-11-2010, 08:03 PM
  2. Coolant? Type A or Type B
    Last Post: 13-06-2010, 07:26 AM
  3. Low level coolant light staying on, even though coolant has been topped up
    By luckyluciano in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-05-2010, 08:40 AM
  4. Coolant type for vr
    By njmauler in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2010, 08:00 PM
  5. Coolant type
    By bajdas in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 08-03-2006, 05:55 PM
Tags for this Thread
