Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By TI3VOM
Thread: What is this on my dash?
    VX Commodore Executive
    Jun 2011
    Central Coast
    Default What is this on my dash?
    I just installed a new head unit with GPS in my VX waggon.
    When installing the GPS antenna on the dash, I found a small plastic piece with wires mounted up against the windshield in the middle between the front demister vents.
    What is this device? It looks like the controller for the auto headlights, but my car does not have auto headlights, and is a base spec Executive.
    I also apparently have the connector for the power windows below the trim in front of the centre box!
    Did all Executives come with the wiring and controllers for more up-spec features?
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    i think (usually wrong though)
    that yeah they all had the same/simmiliar loom.. and they just added the calais/berlina fetures to the calais etc
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    I'm pretty sure it's your key less entry sensor.
    VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
    Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
    VX Exec 01
    Aug 2008
    Melbourne, Vic
    Yep I thought the same thing, the auto head light sensor is actually located in the same spot, and looks exactly the same, but the one in your car won't have the sensor, it will only be your keyless entry sensor.
    Jun 2011
    Central Coast
    Great.
    Thanks for the replies.
    By the way, anyone know how to remove the radio cradle without dismantling the whole dash?
    I removed the two side panels near the floor, but to remove the cradle, looks like I may have to remove the entire dash! Surely there has to be an easier way?
    ( I need to get the cables through the back and then screw the new head unit to the sides. )
    jafo's Avatar
    jafo is offline lurker since 2003
    1999 wh statesman
    Yetisports 3 - Seal Bounce Champion!
    Oct 2003
    adelaide
    look closer there should be a screw or two at the back and unclip the antennea connector and the wiring connectors
    three thing in life are guaranteed
    taxes
    death
    and car repairs
  1. Dash Wiring & Dash Switches
    By JoshSvc in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-03-2009, 01:59 PM
  2. VK Calais digital dash to analog dash
    By mattw in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-12-2008, 08:16 PM
  3. Replies: 2
    Last Post: 02-11-2005, 07:10 AM
  4. Changing a VP standard dash to a Tacho Dash
    By Madhouse_Dave in forum Electrical Wiring / Questions
    Last Post: 01-07-2005, 11:35 AM
  5. Custom Dash + Coloured Dash Lights?
    By ViperVp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2005, 09:08 PM
