Results 1 to 5 of 5
Thread: Tranny oil leak
    5.7ltr gen III v8 325hp
    Jul 2011
    saudi arabia
    Default Tranny oil leak
    My 2000 car has a tranny leak on the 4 speed auto model 4l60e. It was shifting hard from 1-2 gears. I was worried the tranny was bad. But by closer inspection I checked the atf level and it was on the lower circle below the cross hatch. So I put 1/4 bottle atf into it till the top circle and to my surprise now the tranny is shifting really smoothly. I have had the car for two months and the engine oil and coolant level has not changed but the tranny level changed. I looked under the car and there are small droplets of atf on the bottom of the tranny pan and on the ground. My question is where do these 4 speed auto usually leak from. Is it a cheap fix like changing the oil pan gasket or do I have to remove the whole tranny.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Unless you know that the transmission has been regularly serviced, it sounds like you would be wise to service your transmission (or take it to a reputable transmission place) and replace the filter, seal, fluid and pan gasket. Alternatively, you could try and tighten up the pan bolts a little to see if that fixes the problem. However, the pan gaskets get hard over time and if your transmission hasn't been regularly serviced, tightening the bolts up could make the leak worse.
    Commodore M6
    Jul 2010
    East Coast
    i had this once and bascially new hoses sorted this out
    dodged a bullet there
    Jul 2011
    saudi arabia
    Yea I fill the tranny oil up to the top hole and next day the dipstick shows bottom hole, so I have a big leak. The oil never gets lower than the bottom hole it just stays there. And I have to add 1/4 bottle oil every time. I can tell the oil is low when I shift gears. Why does the tranny oil not go below the bottom hole and leak all out.
    Tim Smtih's Avatar
    Tim Smtih is offline Sexy Man
    VXS1 Acclaim Family spec Limited Hardcore Edition
    Sep 2009
    Here.
    I had to replace the bushing at the rear of the transmission where it joins the driveshaft, no more leaks!!
    http://tinyurl.com/MetalisAwesome
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
    Albert Einstein
  1. VR tranny leak from bell housing
    By bennyluvsholdens in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2009, 11:21 PM
  2. Tranny leak.
    By Brin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-02-2009, 11:05 AM
  3. Tranny on the way out?
    By VNCalais98K in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-10-2006, 09:55 PM
  4. HELP! V6 Auto Tranny Leak!
    By nick88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-08-2006, 12:58 PM
  5. tranny
    By freddy69er in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2005, 12:05 AM
