Results 1 to 15 of 15
Thread: Fuel tank capacity problem
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    Default Fuel tank capacity problem
    Just went to fill up my VX, and I the trip was telling me I had 3k's left when I got to the service station. So I filled up but it only took 63litres the pump kept ticking/stopping so I stopped putting fuel in not too sure if somehow I have a smaller tank but im pritty certain its a 75litre tank as all vt/vx's so im a bit puzzled.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    You just can't rely on the distance to empty readings. A lot of factors come into play, if you are facing uphill the reading will be lower than if you were facing downhill, also if the car is leaning in one direction it will make a difference. It will be reasonably accurate on flat ground proving it has had a few minutes to adjust the reading. Sometimes the sender is just inaccurate.
    MY RIDE
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    Well I had travelled atleast 40k's while on petrol light, so when filled up it may of had 3 or so litres left. But only took 62 litres, out of a 75L tank. which seems odd!!
    VE MY10 SV6 A6
    Feb 2010
    Regional South Australia
    I've had my VT reading go from 0 to 30 in the space of 5 minutes. And vice versa from 40 to 7. There's quite a few factors that contribute to the reading, remembering that it is only an assumption by the car.
    FPV GT-P Boss 335 & 2000 VX Berlina 5.7lt (toy)
    Jul 2010
    Dalby
    Quote Originally Posted by Noy View Post
    when u fill it full......does the gauge read just beyond full??
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    mine has said zero but still only took 65L just one of things. just drive till empty then try lol
    1999 Vt Series 2 Olympic Edition
    Nov 2009
    Craigmore, Sa
    If i believe what i know is correct, that the 75L is the main plus a small reserve. You can actually drive around on the light and on zero for a while before it dies. That may not be correct but that is what i know
    2002 VX II Acclaim
    Aug 2008
    You've got a ~10l reserve set. When your dash reads 0kms you've really got 10l left. Which would be pretty much inline with what results youve gotten.
    VT Calais
    Aug 2011
    Ballarat
    Quote Originally Posted by edals View Post
    Except in all cases I've heard, you would then need a new fuel pump. :P
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    try using the hidden trip menu that reads how many ltrs u have left in the tank wen u get down 2 3kms again and see if it says 10ltrs left?
    but as above said its not the best thing 2 do 2 ur fuel pump lol.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by WHYtheFACE View Post
    I've run out of fuel 3 times due to faulty distance to empty readings (around 140 km to empty) and no new fuel pumps needed..
    MY RIDE
    2002 VX II Acclaim
    Aug 2008
    Hence the 10l reserve when your reading says 0km
    wrx884's Avatar
    Mar 2006
    Quote Originally Posted by accentstencil View Post
    Its only bad coz the pump uses the fuel 2 cool it so the more empty ur tank is the hotter it will get.
    VT Calais
    Aug 2011
    Ballarat
    Quote Originally Posted by wrx884 View Post
    I know 2 people that have rooted there fuel pump by running it out of fuel.
    Also my guage is showing a quarter of a tank (110km's to empty) and in the other mode or whatever apparently i have 13L's of fuel left, so much for a 10L reserve
  15. #15
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Yes its not great. i got a bit lost for a fuel station, but always fill up before the light comes on to avoid killing the pump
  1. Strange fuel related, half tank, right corner problem.
    By adomatt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-12-2009, 07:51 PM
  2. fuel tank capacity?
    By Crossy_014 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2009, 12:19 PM
  3. Capacity of VT Long Range Tank?
    By 50LTRv8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-04-2008, 09:10 AM
  4. problem with fuel pump or tank
    By SaGe in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-05-2006, 02:19 PM
  5. VL fuel tank capacity
    By Pistol in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-09-2005, 01:05 AM
