Results 1 to 5 of 5
Thread: water leaking from around the water pump
    Holden vt calais 5 litre
    Nov 2007
    Default water leaking from around the water pump
    just had the inlet manifold seals changed and when the cooling system was pressure tested water leaks from around the pump or water by pass hoses my mechanic wants $50 just to find the problem i think it would be cheaper just to replace all the seals around there myself any advice?
    I might add that the engine is a 5 litre v8
    FPV GT-P Boss 335 & 2000 VX Berlina 5.7lt (toy)
    Jul 2010
    Dalby
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Try tightening the clamps on the two heater hoses. They need to be really tight otherwise they leak. Also have a look at the hole in the bottom of the water pump. If it's leaking from there, the water pump seal is on its way out and you need to replace the water pump before the bearings seize. The other point to be made is that your mechanic would have removed the water pump and other hoses when he replaced the inlet manifold seals. It's his responsibility (free of charge) in the first instance to make sure it's nothing that he did that's causing the leak. I would seriously consider finding a new mechanic if that's his attitude.
    Nov 2007
    Quote Originally Posted by BlackVXGTS View Post
    I don't think they would have removed the pump, the hoses maybe
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    id replace the pump mate, a slow leak it is "ok" for now but overtime the pressure will build up and blow your pump. be on the save side.
  1. Water pump Leaking
    By brianbee in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-05-2011, 06:01 PM
  2. water pump hose leaking?
    By vncruzr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2009, 10:46 PM
  3. water pump leaking
    By darno in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-03-2009, 07:42 PM
  4. Water pump leaking? 97VT
    By Wong in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-02-2008, 08:29 PM
  5. leaking water pump?
    By VNexecutive in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-02-2008, 08:00 PM
