Results 1 to 5 of 5
Thread: vt has no spark
    vt
    Oct 2011
    wa
    Default vt has no spark
    hi all help needed
    siezed a iddler pully and shredded the fan belt now car wont start after replacing the belt could i have damaged the crank angle sensor and should this be the first place to look there is also no spark
    any help would be great also i did the diagnosis check and i have fault 46 this is why im asking about the csa
    cheers carl
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quite possibly. It is pretty common for the belt to damage the sensor, but check to make sure the plug hasn't come loose first.
    Visit my Facebook page
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It certainly sounds like you need a new CAS or maybe the wiring has been damaged.
    It's funny because about half an hour ago I wrote in a reply to a thread that something could be damaged if a belt breaks.
    MY RIDE
    vt
    Oct 2011
    wa
    ha ha maybe your theory is spot on i will check the wiring and replace the csa in needed
    cheers
    vt
    Oct 2011
    wa
    well took off the hb and found that when the belt gave way it wrapped around the back of the hb and broke a piece off the cas 65 bucks and a bit of time and the problem solved a big thanks to the 2 people who replied
    cheers Carl
  1. Replies: 25
    Last Post: 05-02-2011, 07:52 PM
  2. vr - no spark
    By noyzv8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2010, 09:19 PM
  3. Spark lead to spark plug order...
    By james_and_his_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 08:33 PM
  4. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
  5. No Spark for VK
    By cookstvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-08-2005, 11:36 PM
