Results 1 to 2 of 2
Thread: Power steering pump or rack
    VX SS
    Jun 2005
    Default Power steering pump or rack
    Hi everyone
    I got a reco steering rack put in the other day and the system has been bled a though the steering wheel feels a bit tight in some parts.
    The pump is making a slight whining noise, and from what I've read, the system can take a few days to fully bleed properly.
    I'll give it a few days to see if it improves.
    Could a new steering rack kill a older pump?
    Might add also that the previous rack was replaced as there was a bit of play in it (and which I thought was causing a knocking sound).
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    nah changing the rack wont effect your pump, with no acceleration is it hard to turn your steering wheel? and at about 1500rpm it should go easy again.
    in that case it will be your pump gone.
    but also check your power steering fluid, see if its low, that could also be a problem.
    Dan.
  1. VN v6 Power steering Pump and rack pic's
    By nfsuaddict in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-10-2010, 11:40 AM
  2. oil line from power steering to steering rack
    By onmy6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2007, 10:08 AM
  3. WTB vp power steering rack and pump
    By lukas pukas in forum Swap / Wanted to Buy / Trade
    Last Post: 30-11-2007, 05:40 PM
  4. What power steering rack???
    By porkkhunt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-11-2006, 10:54 AM
  5. power steering pump or rack?
    By daniel VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-07-2005, 09:21 AM
