Sometimes when I try to put the window up it goes really slowly and sometimes not work. At other times it goes really fast. This is with all windows. At night when I raise the window up I can see the gauge light dim. Also when I open the lock up somtimes all lock open and sometimes 3 of them open.
If that is with the engine off it could be your battery is becoming weak.
MY RIDE
sometimes its the rubber bailey channel and door rubbers that make your window go up slowly.
I've been advised to use a silicone spray on the runners, can take some of the strain off the window regulator.
http://tinyurl.com/MetalisAwesome
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
Albert Einstein
If its all 4 windows that are going slowly as said could be your battery dying.
but also check your switch it could be faulty and check the wiring (just a few cheap things to look at)
and change your power window relay.
Dan.
