Results 1 to 5 of 5
Thread: wheelbearing ABS light
    VT SS 5.7
    Mar 2005
    Goulburn
    Default wheelbearing ABS light
    Hi guys, vt with ABS.
    Just replaced the front wheelings pluged the abs wiring back in now the ABS light is staying on. Any help if possable please and no i didnt disconnect the battery when i did the job would this mean i have to take it to holden to get it cleared?
    Real cars don't power the front wheels, they lift them
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    I'd say that the ABS connectors haven't been fitted correctly. I know that when I replaced my hubs, one connector fitted easily but the other was a real ba..ard to fit properly. Make sure the male connectors on the mub haven't been bent. Alternatively you could try and bridge pins 5 and 12 of the OBD connector and see what error codes you get.
    VT SS 5.7
    Mar 2005
    Goulburn
    will it still show up even thou its a ls1? i was told that bridging the wires wont work on the ls1 , as for the connecters i pulled it all apart again unpluged them had a look to make sure no pins were bent everything seems ok. im about 5min from throwing spanners at the car lol
    VT SS 5.7
    Mar 2005
    Goulburn
    Just discovered,when the car is cold take it for a drive NO ABS LIGHT comes on. after the car warms up the light comes on AGAIN . is it possable that 1 of the wheel bearings are faulty?
    VT SS 5.7
    Mar 2005
    Goulburn
    After messing around and breaking afew things found the problem, the passenger side Wheel bearing ABS sensor must be stuffed .Pluged the old ones in and the light went off pluged the new 1 in light comes on. is there any way to swap my old ABS sensor t othe new 1 or do i need to order another Wheelbearing hub?
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. How to Wire up VZ Interior Sunglasses Light to a VY Centre dome light connection
    By VYSS_Black in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-07-2011, 04:42 PM
  3. Replacing light bulb behind demister / interioir light / dimmer switches
    By seabs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-05-2011, 09:57 AM
  4. vr calais head light and interoir light brake problem
    By lestat2220 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 01:38 PM
  5. Berlina/Calais/Statesman Roof Inteior light into basic model with standard light
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2008, 10:07 PM
