Results 1 to 9 of 9
Thread: Steering Wheel Controls
    VX Commodore Executive
    Jun 2011
    Central Coast
    Default Steering Wheel Controls
    I saw a post on this forum a few weeks back of a new steering wheel control adapter for generic head units that does not use infra-red but is wired in to the head unit.
    I have done a search but could not find the thread.
    From memory, someone found the adapter but had not yet tried it. I think it cost around $50 - $60.
    Anyone know what I am talking about?
    Cheers.
    VX EXEC 3.8's Avatar
    VX EXEC 3.8 is offline Police Spec VX Executive
    VX Executive 3.8 9C1 pack
    Mar 2010
    NSW
    It is my understanding that you need to get a Head Unit that supports input from remotes, E.G Some Alpines have this. The input is usually in the form of a 3.5mm plug. Alpine sell their units with the ability for this but you need to buy an Alpine steering wheel controls adaptor (SWC-C10)
    For a lot of other units, if they say they are 'ready' for steering wheel control remotes, they need a 3rd party branded interface for the controls on the VT/VX to be able to plug in.
    Such interfaces are like this one 'The CAT' THE CAT
    The cat also works with steering wheel control 'ready' alpines.
    I'm also fairly sure some kenwoods work with these adaptors.
    2002 VX II Acclaim
    Aug 2008
    Alpine headunit hard wired remotes use a digital signal. if you've got a pioneer like me, you can just pull apart your buttons, and replace the resistors with pioneer rated ones and will all match up
    Jun 2011
    Central Coast
    Mine is a cheap Chinese double din head unit that has DVD/CD/GPS/Radio etc. It comes with three wires (+, - and negative) for the steering wheel controls. You can then program the HU to recognise various signals coming from the ssteering wheel controls and assign them to a function on the HU.
    So, like a smart-arse I just connected the Neg to the earth, and the +ve to the brown wire from my wheel. The result was the voolume went straight to the top and could not be lowered (really annoyed the neighbours!!).
    So, obviously I need some kind of adapter. Just not sure what type. I do not want the infa-red remote adapter.
    Cheers.
    VX Executive Wagon
    Oct 2006
    Quote Originally Posted by jughead1 View Post
    Thinking of getting the same - Not a WTHYOU is it? - I was hoping The Cat would solve a problem like this. Apart from the steering control problem does the rest work OK?
    [SIGPIC][/SIGPIC]"There's one thing I've got to say - Its better to burn out than to fade away!"
    VX Calais
    May 2005
    NZ
    there are threads in the car audio section on steering wheel control interfaces.
    i've got one from these guys, iPod Integration for your car and More by Pac-Audio - Connecting you to the future
    can't remember the price, but pretty sure was over $100 nzd
    they had different versions to suit different HU's and are pretty easy to install.
    mine was the IR model, mounted the IR sender in the steering column below the wiper control. wire it up to power, earth and the appropriated steering wheel wire behind the HU, and programe it to suit.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Jun 2011
    Central Coast
    Quote Originally Posted by ranger View Post
    No, mine is a no-name.
    But it does have a "learning steering wheel control" feature. And I read on another post that the controls go through the BCM. If I bypass that, it may work. Otherwise I will just dump the controls.
    WH Caprice 5.7L
    Sep 2011
    Roxby Downs
    either a SWI-PS or a SWI-X (ones for infra-red the other is for 3.5mm hardwired remotes).
    Also an Aussie mob called Stinger have a Cat10 device that should work fairly sweet.
  1. steering wheel controls without a SWI!
    By Vu_ in forum Car Audio
    Last Post: 12-08-2010, 04:46 PM
  2. VZ sc6 steering wheel controls
    By impulsed_sv6 in forum Electrical Wiring / Questions
    Last Post: 29-07-2010, 09:16 PM
  3. vx steering wheel controls
    By pac3y in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-01-2009, 09:39 AM
  4. Steering wheel controls...
    By shaded_vs in forum Car Audio
    Last Post: 15-12-2007, 09:22 PM
  5. Steering wheel controls
    By garywg in forum Car Audio
    Last Post: 08-05-2007, 10:40 PM
