Results 1 to 9 of 9
Thread: fitting ls1 extractors help
    VX Clubsport M6, Subaru Brumby-daily, TM Magna
    Sep 2008
    Auburn
    Default fitting ls1 extractors help
    hi, have just got some 4-1 extractors and high flow cats, i have installed the pass side which took me ages and plenty of bad language! i had to remove power steering pump and res, air box, coolant tank, coil packs. so just wondering what i have to remove to fit the drivers side? do i install from underneath?
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    WTF??? sounds like your doing it the hard way, come up from under the car. Only thing i had to do was drop the driver side of the power steering rack.
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
    Sep 2008
    Auburn
    cheers mate, so undo two bolts on steering rack and drop it a little? undo high pressure line aswell?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You will need to undo the two bolts holding the rack in, and the bolt on the coupling holding the shaft to the rack. Move the coupling over onto the chassis rail. Pull the rack off the mounts and turn the shaft so that the rack moves to the right as far as possible. Remove the brace on the chassis rail as well. The header will slide up from the bottom.
    Visit my Facebook page
    Sep 2008
    Auburn
    cheers mate, got it all done after work tonight. what a job! i wont be doing that again. exhaust has a bit of a leak where it connects to my x force cat back so im gonna take it to an exhaust shop because the xforce didnt quite line up the best. other than that it sounds like an old beasty 5lt and all the drone when cruising has gone! thanks naaf, ill be getting a vid up when i get the leak fixed.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You obviously got the cats the right way around? They look like they can go on either way, but if they are the wrong way around, the system won't line up with the flanges. They should have been marked left and right anyway.
    Sep 2008
    Auburn
    umm, the four bolts bolt onto extractors and the two bolt holes bolt onto cat back exhaust. are both cats the same or is one for pass side and one for drivers side?
    Sep 2008
    Auburn
    ok thanks naaf your a champ, there wasnt any stickers on the cats but there was a few engraved numberson one side so i swapped them around so numbers were toward the ground instead of being toward bottom of car and they fit perfect! no more leaks.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    No worries. Unusual that they weren't marked left and right though.
  1. fitting extractors
    By Kcboiye in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2011, 05:06 PM
  2. Fitting Extractors
    By sxc_sound in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-09-2010, 10:23 AM
  3. fitting extractors to a vy v6
    By peeingeye in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-09-2009, 03:45 PM
  4. fitting extractors to VH V8
    By yobbo88 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-03-2008, 03:44 PM
  5. extractors and fitting
    By stes mad VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-05-2007, 09:19 PM
