Page 1 of 2 12 LastLast
Results 1 to 25 of 42
Thread: 200 kms out of a full tank of premium fuel
    VR Calais
    Mar 2011
    Plumpton
    Default 200 kms out of a full tank of premium fuel
    Hey guys I sent my car to a local wrecker about 2 weeks ago and it came back and the guy said it needs new oxygen sensors, I replaced the fuel pump, the fuel filter and both oxy sensors, it's got me stumped as to why it's chewing fuel, it's only a standard vx ss with a dual 2.5 xforce cat back exhaust system,
    Does anyone have any suggestions ??
    1993 VR CALAIS 5 SPEED MANUAL,Lowered all around on pedders, 20 inch G8s, Option audio front splits, option audio amps, sound stream subs, pace maker extractors, high flow cat, 2.5inch lukey cat back exhaust
    VE Clubsport
    Mar 2010
    Middle of Nowhere - WA
    There is a thread in the VE section similar to this... Have a look through & see if anything on that one helps.
    I'm a girl... I'm blonde... But I drive a really nice car
    '97 VT Calais
    Apr 2007
    Could really be anything from flat tyres to faulty thermostat.
    Check all the fuel related causes. Plugs, leads, injectors. Temperature related, cooling system, thermostat.
    Blocked cat?
    Reset Ecu and check codes?
    Inflate tyres to recommended levels and stop driving like a hoon?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Run a tank of standard fuel and see what happens. If the car is not tuned to premium, it won't run as economically. But having said that, 200kms is pretty bad, were you giving it a lot of stick?
    Visit my Facebook page
    VR Calais
    Mar 2011
    Plumpton
    Na it's driving it like grand pa would but I'll try normal fuel but not e10
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The LS1 has a bad habit of chewing up RH factory cats. If one or both cats have broken up and partially blocked the exhaust, it would cause really bad economy.
    VR Calais
    Mar 2011
    Plumpton
    How can you check??
    Hektic's Avatar
    Hektic is offline Donating Member
    2006 VE Omega Impulse Blue
    Jun 2010
    Remove the exhaust from the cat Back and have a peak throgh with a torch if its blocked youd see loose honey comb look
    http://forums.justcommodores.com.au/...lue-omega.html
    Check Out my 2006 VE Impulse blue Omega
    pommyVL's Avatar
    pommyVL is offline PommyVL
    VX 5.7 SS
    May 2010
    Newy NSW
    Im a pretty normal driver and with a full tank of premium i get about 320km around newcastle.
    If i razz it i get about 260 and if im a granny i get about 400km max
    my car is overdue for a full service and filter change too because my gearbox is ###d..
    mates in England driving 1.0L ricers
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Fuel regulator shitty injectors ?.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    VT SS LS1
    Oct 2008
    gold coast
    i had same problem. cleaned the filthy MAF, reset the ECU and it was much better.
    VR Calais
    Mar 2011
    Plumpton
    If my cats r blocked how do I go unblocking them or is my only legal option replacing them???
    Sent from my GT-I9100T using Tapatalk
    VX SS
    Jun 2005
    VR Calais
    Mar 2011
    Plumpton
    Engine lights on but that's cause of oil pressure switch, everything else is ok
  15. #15
    VX SS
    Jun 2005
    You've had it scanned and its only the oil pressure causing the fault code?
    Has it always chewed through the fuel or only when you replaced the oxygen sensors, fuel pump etc.
    When you get low on fuel, is it the warning light going on? The other thing that might cause it is if your fuel sender is reading the tank wrong?
    How many litres can you put in when its empty?
  16. #16
    VT 2
    Nov 2008
    If your cat's blocked it's because the honeycomb holding the catalyst has collapsed. Only option is to replace.
    Reset the ECU is a first step. Necessary because it uses recent historical records to weight it's current tuning. Remove the records and it will default to factory tune.
  17. #17
    VR Calais
    Mar 2011
    Plumpton
    Filled up tonight from this point n it took 40.04L
    Doesn't look right hey?
    Attached Thumbnails Attached Thumbnails 200 kms out of a full tank of premium fuel-uploadfromtaptalk1320748692742.jpg
  18. #18
    VX SS
    Jun 2005
    Id say its slightly wrong and the fuel level in the tank is reading slightly wrong. Check what amount the sender is reading in the fuel tank by accessing the service menu through the trip computer (hold set and mode i think) before turning to on position and then let go.
    Then fill and see how much it reads. When its half way see again how much.
  19. #19
    VT
    Apr 2005
    QLD
  20. #20
    VR Calais
    Mar 2011
    Plumpton
    Wrecker n also qualified mechanic, I thought it would of been safe
  21. #21
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
  22. #22
    gowon's Avatar
    gowon is offline ( . Y . )
    vx ss
    Mar 2010
    deniliquin
    having a crook oil sender can cause some of your problem, i've just been though the same thing. a few weeks ago i noticed my exhust smelled rich and used lots more fuel. dtc came up a week later as over voltage oil pressure sender. replaced the sensor and fixed the problem. i dont know why it caused the tune to go rich. maybe some sort of limp home mode or engine protection. i'd still check everthing posted above as well
  23. #23
    jakstas's Avatar
    jakstas is offline Auto Elec
    VT SS S2 M6
    Jul 2006
  24. #24
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    Quote Originally Posted by jakstas View Post
    Hmmm 200k's to a tank. Sounds about right for my ride.
    Wow, I get a minimum of 650km, and in reality that's because I keep having to go into town. I get much better on freeways.
    The New Ride - The Class 2 Shuttle Craft (VE)
    I'll be he comes to get you, some shopping trolley kind of thing, that gets you where your going nice and slow... Well off you go that's fine, the pleasure's all mine.
    When I light the nitro on my HQ 454 Monroe!
  25. #25
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    And yours is a v6..
  1. full tank hwy k`s same as full tank of city k`s
    By pillzor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-11-2011, 10:06 PM
  2. Fuel tank full of crap, keeps blocking filter
    By blinky666 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-07-2010, 09:46 PM
  3. Who Uses Premium Fuel?
    By Robbo VS3 in forum General
    Last Post: 31-08-2009, 10:20 AM
  4. calling all vs owners how many km's out of a full tank of fuel.
    By cyborg66 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-08-2009, 09:03 PM
  5. full tank of fuel on the road
    By burnsy150 in forum General
    Last Post: 18-02-2008, 05:24 PM
