I have a VT Berlina II with the v6 motor.
1. Is there a way to have the climate control permanently display the outside temperature - and also display the inside temperature/climate control settings at the same time? Hope that makes sense :/
2. My rocker cover gaskets are leaking. How much would these normally cost and would most repco type places stock them.
3. My Commodore is bog stock. I'm looking at putting a Mace 12mm Plenum, 25mm Intake Insulator and Memcal. I don't plan on doing much more than that as I have a young son, so I don't want any exhaust systems or anything (the standard exhaust is nice and quiet, perfect for my 8 month old). I'm not really after outright top-end power, but would like some more low-end torque and hopefully an improvement in fuel economy. I get good economy now, 11-12L/100km highway/city.
How much more grunt will I have down low? Will I gain much up to and if so, how much? Will the combination of these three mods improve my fuel economy at all - or am I at a risk of going the other way. I do some long trips with towing (fuel economy goes up to around 17-18L/100km), hence my interest in gaining some low end torque but not if my fuel economy is going to go bazerk!
Car is recently serviced (New plugs & leads, engine oil+filter, fuel filter, air filter. Cleaned MAF/TB/IAC/Intake Temp Sensor. New Oxy Sensors).
Thanks for your help
Edit: Oh - and I always try to use BP Ultimate 98 when available.
One other thing. After I replaced the Oxy Sensors I disconnected the battery for a while. When I got back in, she had heaps more power and would spin the wheels at will. Now that I've been driving it for a few weeks, it won't do it anymore. The car runs fine, this just seems strange.
Gotta stop
Answer to #2- about 20-30$ and they are very easy to replace, and most repco, supercheap and autobahn should have them.
hope others can help with your other questions.
Dan.
Thanks Dan!
Gotta stop
Does anybody know?
Gotta stop
I found 1.9 rockers give good mid range power increase and improves economy providing you drive with a light foot. Haven't tries the insulators though
