Results 1 to 4 of 4
Thread: vt ss abs sensors, URGENT HELP NEEDED QUICK!!!
    vt ss
    Mar 2011
    sydney
    Default vt ss abs sensors, URGENT HELP NEEDED QUICK!!!
    hey guys, i replaced my diff a while back having blown it up and when i put it all back together the abs light came on, my mate said it could be due to the abs
    sensor being to far away from the wheel speed sensor.
    what distance should it be between the sensor and the wheel speed sensor? and what could happen having had it not operating for so long?
    cheers,
    chris
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    ABS sensor air gap - 0.13 to 1.0mm.
    Edit: Sorry, these are the figures for a VS Commodore. Can't find the equivalent info for a VT.
    vt ss
    Mar 2011
    sydney
    Aug 2004
    What I suggest you do is display the ABS error codes that have been set. You will need to connect pins 5 and 12 on the OBD diagnostic connector and count the number of times the ABS light flashes between pauses. This is similar to how you display the engine/trans error codes. That will tell you specifically what is wrong with the ABS.
    The above assumes that you have a VT1 SS (ie. Holden 5l engine) and not a VT2 (LS1 5.7l engine).
  1. Need urgent help, fuel pump quick disconnect?
    By maldotcom2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2010, 07:24 PM
  2. Quick question, upper control arms, urgent.
    Last Post: 21-03-2010, 02:44 PM
  3. [Urgent]A quick speaker installation question!
    By Jordan [VN] in forum Car Audio
    Last Post: 13-07-2009, 09:27 PM
  4. urgent help needed!
    By boourns in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2007, 10:56 AM
  5. Quick urgent help required!
    By matty193 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-09-2005, 05:19 PM
