Results 1 to 15 of 15
Thread: 2 hole mod for cai
    vr wagon
    Aug 2010
    vic
    Default 2 hole mod for cai
    Only have my iPhone and finding it hard to search through threads on this. Wanting to do the 2 hole mod or commonly known bunnings cai. Thinking of going one hole In the side of lower airbox with pipe running down into the gap in my front end. Then the other from bottom front airbox to behind the headlight. Does anyone have pics, or ways to best go about this? Pipes to use and sizes and what to do for behind the headlight? While I'm there wanting to do a 4"intake. Any suggestions or links on this would be great too. Thanks guys.
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    cheaper and more effective...
    by pod filter that fits end of Air Flow Meter
    take Intake air temperature sensor ffrom airbox
    use METAL WASHER from Intake air temp sensor (IATS) to find size of hole needed for drill bit
    drill the END of the pod filter out stick IATS through hole
    put metal washer over IATS (as it was in old air box)
    fit pod filter and afm to car
    plug it in
    enjoy about 1-3kw increase (3 with extractors and standard tune... (engine used for this check was old and shitty))
    recommend this rarther than running conduit form the WET road surface(rain=water up pipe) to you air box....
    just an opinion many will have others
    note without a custom tune the peak air flow (within standard tune) is minimal(extra ??cfm is <size of idle air control valve and NO air filter) and it will choke the air at valves and throttle body and afm and exhaust etc.... so too BIG is pointless....
    vr wagon
    Aug 2010
    vic
    It's an l67 so will force the cold air in, it has a k&n panel fitted. A pod filter in engine bay will cause too much hot air going in from the engine bay. You would have to be driving in a big arse puddle for water to travel that amount of distance as the pipe runs downwards from the air box. Was thinking some mesh over the front to stop bugs though. The Otr fitted sucks a crap load in and have to empty them out every couple of weeks.
    VX Clubsport M6, Subaru Brumby-daily, TM Magna
    Sep 2008
    Auburn
    dont do the cheap pipe to the bottom mate, been there done that on my old vt. sucks up so much crap! and somemhow there was always a bit of water in the box and a wet filter (during the wetter months) i didnt notice any difference in throttle response or power.
    vr wagon
    Aug 2010
    vic
    What do you reckon about the enclosed box behind the headlight. Like the aftermarket ones?
    Sep 2008
    Auburn
    i have one on my clubby, i guess its standard on vx hsv's as ive seen a few at drags with pass front light missing. which is different to other gen 3's which have an air inlet in the fender. i guess its allright it looks stock and works well its gotta be alot better than a pick up on the bottom of the bumper.
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Quote Originally Posted by CHA53R View Post
    Like this? Got it on mine,from MACE.Looks nice and very efficient.
    vr wagon
    Aug 2010
    vic
    Yeah, does it pick up much cold air there? Wanting it running a bit cooler under the bonnet and the Otr seems to be doing crap all except bug catching. Know I need manifold heat shields to stop the heat rising in there so I'd rather spend money on them and have a go at a cai. I know there's no real gain kw wise but the car likes the colder air so just want it as much as possible.
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    water enters the pipe in mist and steam... thats how it randomly got wet (worse in wet rain lol)
    those boxes are awesome, cause they catch all up draft that travel around for the bumper
    (like blowing candle out around a glass) and the distance is the same as standard generally eliminating the water effect.
    vr wagon
    Aug 2010
    vic
    Yeah, I'm going one or of them. They look tidy too. What is the design of the mace ones? Is it a full enclosed box except at the front or does it cover the side and back with a lid? Are they just plastic sheets or made of something else?
    vr wagon
    Aug 2010
    vic
    Ended up going a bunnings cai. Mace style. Loving the whine.
    VT Calais
    Aug 2011
    Ballarat
    nice!!, what's the plastic you used called, and how much? Have been thinking about doing this for far to long
    vr wagon
    Aug 2010
    vic
    It's aluminium sheeting. Seen a step by step thread on installing the mace setup and thought I'd just do it myself. Judging by the mace pics. It's pretty close. Would have liked a thicker alluminium but had a ball making it. Hardest part was making a cardboard template. To work off. Once transferred onto the sheeting. Came up a treat. Couple more tweaks. Covering small gaps, a paint and installing the 4" intake pipe I got today. Will be happy. For $50 I think did alright. The Whine in the supercharger Is just unreal
    VT Calais
    Aug 2011
    Ballarat
    Oh aluminum, and the cardboard template would make it so much easier, I've got some sheet stainless steel sitting around so i might give that a go when i get around to it.
  15. #15
    vr wagon
    Aug 2010
    vic
    Took a couple of hours of playing around with cardboard and about an hour cutting and bending the sheet and fixing it to the engine bay,hooking back up the sensors and the pod
  1. tow bar hole
    By vtspeed in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-03-2011, 10:46 AM
  2. 2 hole and k&n
    By az_sv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-11-2009, 12:25 AM
  3. 2 hole mod VS
    By Shelfish in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-05-2009, 12:44 PM
  4. Hole, what is it?
    By Chirpstr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2007, 05:50 PM
  5. wat hole
    By vn chicky in forum Jokes/Humour
    Last Post: 19-04-2007, 10:41 PM
