Results 1 to 6 of 6
Thread: Alternator squeak?
    VT Berlina
    Sep 2010
    Default Alternator squeak?
    Hi everybody!
    (....Hi Dr. Nick!)
    I've got a pretty vague question... Not sure if i'll get a resolution.
    On my ecotec V6, the alternator or one of the belts seems to have developed a squeak. The higher the revs the faster the squeak etc. Just wondering if this has happened to anyone else or is a common problem - and possibly an easy fix?
    Car is due for a service shortly and as far as im aware its not doing any damage... Just a painful experience - only way to get rid of it is turn the music up
    Thanks homies!
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    If the belt is shiny and/or has little tiny cracks around the edges it's due to be replaced. Do a diagram of your belt then pull it off and spin the alternator and all the idler pulleys one at a time. If they are anything other than smooth, free, and silent then they need to be replaced. A worn belt and screwed pulleys can cause a squeaking sound.
    WTB: VR/VS S/SS Lower front bumper lip/spoiler
    Tim Smtih's Avatar
    Tim Smtih is offline Sexy Man
    VXS1 Acclaim Family spec Limited Hardcore Edition
    Sep 2009
    Here.
    As above, i needed to replace the bearings on two (idler pulleys) and the third entirely. Now no more squeak.
    http://tinyurl.com/MetalisAwesome
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
    Albert Einstein
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    As above, likely a bearing or belt. My guess is a bearing though. To check them, have the motor idling and get hold of a long flat bladed screwdriver (or similar) and put the end of it on the head of the bolt through the idler pulley. Put your ear to the other end and listen for any bearing noise (works like a stethoscope). If it doesn't sound smooth it needs replacing. Check both idlers and the tensioner pulley this way.
    "wait... inflammable means flammable???" Sorry, Dr. Nick quote lol
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    VT Berlina
    Sep 2010
    Thanks for the help guys.
    After a fair bit of testing etc. It's seems its definitely the belt causing the noise. I got the belt tested and inspected by a mechanic and according to him its okay.... Is it just best to buy a new belt? My mechanic suggested silicon spray - but i assume this would be only a temporary fix, and i'm pretty reluctant to this as it shouldnt need lubrication anyway?
    Any helps appreciated!
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    the betls are like 30$ for v6, the silcon would fix it but not forever.
    stay on the save side and dont be cheap and get a new belt, and keep your old one in the back of the car incase your one breaks.
  1. squeak
    By jimmythesaint in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-09-2011, 09:03 PM
  2. VX Squeak?
    By Ray De Man in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2009, 02:14 PM
  3. bloody squeak
    By 2greedy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-03-2007, 07:46 PM
  4. Squeaky Squeak
    By shaggerz in forum General
    Last Post: 01-05-2006, 01:04 PM
  5. Brake squeak
    By paddyj in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 07:25 PM
