My vx is stuck in my garage as of yesterday. It appears that the coolant reservoir has a crack in it and will not hold any water. Can anyone tell me how to get it out?
I think you have to remove the plastic splash guard from the wheel arch to access the tank.
MY RIDE
Just did this today.
Remove the plastic overflow pipe that goes from the radiator to the bottle, just pull it out, it has a grommet built into it.
There is one plastic screw and a ramset type plug that holds the inner guard to the coolant res, I tried unscrewing it and even had a flat srew driver between the guard and the res to encourage it to come apart, no luck. In the end I just levered it and popped it off. Once off I was able to get the screw out and reuse the screw and ramset thingy.
There is also 3 x 10mm screws. 2 towards the front bumper and one on the inner rail, reservoir drops down and you can remove it.
Is that the same in a VZ alloytec 190kw?
