Results 1 to 10 of 10
Thread: RH headlight
    1999 Vt Series 2 Olympic Edition
    Nov 2009
    Craigmore, Sa
    Default RH headlight
    Hey i have a question cause i am stumped. I replaced the globes in my headlight and since then it sometimes decided to not turn on, however after i slapped it it would switch on and be fine. However now it won't turn on at all, this includes the parker.
    It isn't the globe because when i switch on HB it turns on
    Cheers, Normie
    Nov 2009
    Craigmore, Sa
    VT Berlina
    May 2011
    Chirstchurch
    My memory isn't the best but as far I remember the High beam are actually separate bulbs so it could be that the plug in the back of your low beam bulb isn't plugged in properly.
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    he is correct low beam and high beams are separate bulbs so check them first
    then check your fuse could be blown.
    Dan.
    Nov 2009
    Craigmore, Sa
    Quote Originally Posted by Kdouble View Post
    Yeah i checked all that and it was fine. The parker doesn't turn on either so i am stumped. And yeah i know the HB is seperate, but when i turned on the high beam the light for low beam switched on also.
    Do you think it could be the switch inside?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The fact that it used to work when you slapped it would indicate a bad connection somewhere.
    MY RIDE
    VE MY10 SV6 A6
    Feb 2010
    Regional South Australia
    I invariably had my VT tail lights and window brake light come on and off. A little tap here and there usually did the trick, but I can't count how many globes I had to replace in the back half of that car. Number plate lights, boot tail lights, actual tail lights, window brake light. All of the above. Thankfully light globes are cheap Lol.
    Killr6's Avatar
    XR6T
    Sep 2010
    Hervey Bay QLD
    Quote Originally Posted by burleighboy86 View Post
    you will have bad wiring somewhere shorting out the rear end.
    VE MY10 SV6 A6
    Feb 2010
    I thought it was that, but the quick fix was always the way I went instead of delving deeper into the problem. Time and money were things I didn't have Lol.
    Nov 2009
    Craigmore, Sa
    Well i have an update:
    I went for a cruise with two of my mates tonight and they told me that my lights kept switching between both on, the left one only and the the right one only. This has made me more stumped than before.
    Any idea what it could be now?
  1. No headlight?
    By nayev in forum VE Holden Commodore (2006 - ?)
    Last Post: 13-03-2011, 12:30 PM
  2. how much should i pay for a new VS headlight?
    By nickdanger in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2007, 08:42 PM
  3. Headlight
    By luvmycommodore in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-11-2005, 02:36 PM
  4. headlight
    By robcom in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-11-2005, 08:13 PM
