Wtf my car isnt starting as soon as i turn it over it starts then dies strait away..... It started the 1st time and when i was trying to warm it up it cut out and hasnt started since help!! Ha
Is the immobiliser turning off (flashing light in mode switch)?
MY RIDE
Unlock the car hop in. Lock the doors with the key (if central locking still works) then unlock it and quickly try start it. Mine did this. I used this as a bandaid for a week then wouldn't start at all. See if it works for you. Get a new key programed by a tech 2 at Holden. $130. I don't like using Holden but I have read that many threads about locksmiths not programing the key right and bam people get stuck and can't get the car started again. Holden told me that if your buttons are showing wear replace the key. About every 5 years depending on use.
Won't it just not turn over at all if the immobiliser is on? Can you hear the fuel pump priming when you turn the key on?
