Results 1 to 20 of 20
Thread: whats the better oil
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Default whats the better oil
    i have a 1997 vt berlina that has done just over 106k i was wondering as the v6 is getting on in age now ? should i move up to a better grade of oil on my next service?( next service being done next week) and if so what brand of oils should i use? and what grade would suit the v6 with 106k?.............any feed back would be great help.................cheers...........have a good week end...........tony
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    Shounak's Avatar
    Shounak is offline The Kicking Horse
    VX Executive S2 + XF Panel Van Project
    Apr 2005
    I was talking to the guy who services my parents MG ZT.. That car needs an oil change evert 25k, he said it was due to the synthetic oil.
    He said that if you used a good quality synthetic oil, I think he said mobil 1, then it would probably be the same for a commodore. An oil change every 25k cuz the oil's fully synthetic and lasts longer..
    Is that true? Sounded way too good to be..
    Sep 2005
    whats the better oils
    rattattack1313 Guest
    Cool
    I run Pensoil in my Green Eyed Beastie..................and have put slightly thicker oil in this time, because it's the original motor, and has a few miles up now, and bits are getting a little worn...............
    Sep 2005
    yes i may try the pensoil this time around ___ are synthetic oils any good? mobil 1???????? cheers
    Cool
    Make sure your wallet is loaded b4 you get the Pensoil.....it aint cheap.............syno oils are ok, but all my racing mates use the pensoil...
    Sep 2005
    ok pensoil it is then rat...the cost is ok with me ill get some on moday....how many liters do i need for the vt and should i grab an extra 1 or 2 liters for later as a top up?
    Cool
    if you are doing a filter change as well( about $8.00 for a new oil filter) you need 4.1 liters...but it is good to have a bit spare, so get 5 liters...SAE5W-30 in the hot weather,10W-30 for winter................
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Quote Originally Posted by rattattack1313
    VT 3.8 w/filter takes about 4.9 litres of oil.New oil filter is about $4 retail(s/cheap)Whatever u do dont use penzshit.We've lost two VT/X engines to it.If u can afford it use Motul or Fusch.
    Sep 2005
    PENZOIL NO good...mmm ok ill take that in mind....were do i get mtul or fusch.and how much are these oil? thanks for the feed back.....................................cheers
    VT Berlina
    Mar 2005
    Well i have used Penzoil and Shell and caltex, valvoline on my VT Berlina and i can say there is only 1 oil that has really satisfied my engine after trying all of them. And gave my engine a really good orgasm i tell ya.
    It is mobil sythentic. The stuff the use at holden i think. For some reason you can never go wrong with mobil except the price which makes you start swearing a lot.
    But it keeps the engine smooth and responsive so in the long run i think its worth the money.
    Sep 2005
    yeah mate im thinking of getting some of that also................ill let ya know what it ended up costing..................cheeers
    VH Wagon SLX 253
    Nov 2004
    Southern Highlands
    ive used BP Visco the last few changes, havemt looked back since! Tried Helix, Penzoil, Castrol, reckon Valvoline is next best option.. The BP stuff just seems to be top quality oil, and doesnt get as dirty as the others. Has a nice purrr in it too lol
    VT Berlina
    Mar 2005
    BP has oil? didn't know that. hmm.......maybe i will try it out on the next service
    I can say valvoline is excellent on lawn mowers. But my gut feeling tells me that they have improved a lot recently for car engines especially for the V6 ecotec.
    MG
  15. #15
    Sep 2005
    oils aint oils..........wow so many differant oils......im not sure what ill be getting but it will be the best i can get..................bp.mobil1.visco,penzoil and many more .........ill let ya know what i use.....................cheers
  16. #16
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    Quote Originally Posted by magomes
    Unless you get the german blend of Mobil 1, i wouldnt touch the crap.
    I use Valvoline full synth as i get it through work.
    Sent the oil off for analysis after 5000k, came back at 97% efficiency, sent off the second analysis start of this week for 10000k. So i will post what the results are. We use valvoline in the Prime movers here. All our mechanics swear by it, and i do also, after 5000k in my motor oil had barely discolored
  17. #17
    mattid-vxss Guest
    Hey there, good one is the valvoline synpower full synthetic,15w-40 try not to go to thin oil as the VT's are starting to get a few K,s now, and you will end up getting tappet noise, he Mobil1 is also a top oil however is much dearer and not justifyably better for the price difference. Valvoline oil filter VO6 sells for $5.99 at supercheap, Synpower 5lt will set you back approx $60.00. Also maybe take a look at Shell Helix Ultra, not too bad either and a popular choice for the Vt/Vx.
    Hope this helps.
    Matt
  18. #18
    MY10 VE SS-V wagon
    May 2005
    I got my car serviced by Midas and got semi synthetic Valvoline 15w-50 oil.
  19. #19
    grafxworld's Avatar
    grafxworld is offline KLRBASS
    VT GTR EXEC S1 - SOLD off
    Feb 2005
    go full syth. oil not half ass oil,
    just don't forget to change it , you can also help your oil by changing your filter twice during your oils life keeps it cleaner longer, you have to remember most of AU is considered extreme duty , dusty , hot or humid, stop and go traffic. which means you should change it more often
    tappet noise usully means worn parts or a leakdown in lifter, you can clean them in and reinstall it to fix em
    see the other post for more info in oil
  20. #20
    RKZ234 Guest
    I've used Castrol TXT Softec and the more recent version TXT Softec LL-01 for a very long time in all our family cars, which have included, XF Falcon, TG Gemini, 2 x V8 Statesmans, Corolla, TX5 Ghia V6, 2 x VW Golfs, Volvo Turbo, VT & VX Commodore and S/C VX. All vehicles had 10,000 km services or 6mths whichever came first. Only the current Statesman has had the engine touched. A head gasket went at about 150,000km. 1st Statesman did 300,000km and the other is up around 280,000km at the moment.
    It's a fully synthetic 5w30 rated oil, specifically designed to meet longlife specifications demanded by BMW, Mercedes and Porche, whereby the oil is required to remain stable and still meet specification after 20,000 km use. If you buy 2 drums at a time, it costs about $175 delivered per 20 lt drum direct from Castrol. Castrol Part no. 114368.
    20lt is the smallest it comes in. It also comes in a 205lt
    No I don't work for Castrol or have shares in the company!
  1. Whats Your Rpm????
    By harvs01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-03-2008, 10:46 PM
  2. Whats Next??
    By johnvtls1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-10-2007, 10:39 AM
  3. whats better to use?
    By greatone in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-03-2007, 09:08 PM
  4. whats this?
    By Rishy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-12-2006, 12:42 PM
  5. whats the go with this
    By chevy_big_block_bro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-09-2005, 05:09 PM
