Results 1 to 6 of 6
Thread: vt series 2 water leaking issue
    vt
    Oct 2011
    nsw
    Default vt series 2 water leaking issue
    I recently bought a vt series 2 (2000 model) and had it all serviced etc etc... when i got home from the mechanics i oped the hood to check the oils and noticed that there was water leaking near brake master cylinder , draining down toward the battery. the leak is miner but it i leaking. i noticed there is a couple hoses there connected to the heater tap next to the leak. is it most likely to be the heater tap and do they commonly play up ????? i need this problem fixed !!! Thank you.
    1997 Vt GTS Build 78
    Aug 2009
    East Gippsland
    Go back to the mechanic and ask the WTF, was not like that when dropped off.....If no love there......Try to tighten hose clamps, and/or add another clamp. If the water is dripping from connection the most likely some lasy mechanic has been leaning on it while doing the service, may have cracked the join behind hose....Then you have to solder fix or replace.........hopo you have some luck should be fairly easy fix
    vt
    Oct 2011
    nsw
    yeh that makes sense he must have lent on it while filling up the transmission with oil, thanks for the help
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Just be careful when tightening the hose clamps because the tap is made of plastic and becomes very brittle with age.
    MY RIDE
    VS Stato l67
    Mar 2009
    Melb
    I just replaced a VT heater tap on saturday. It was leaking coolant and was so brittle that it snapped in my hands when I tried to get the hoses of.
    It was only $40 for a gates heater tap from supercheap and pretty easy to DIY.
    Jarrad is offline Sherminator
    Silver Ex Cop VX Wagon
    Oct 2006
    Wollongong
    Quote Originally Posted by monkeys437 View Post
    +1 for this. Its a very easy job to do yourself, mine was cracked inside the hose and the tap just snapped off because it was so brittle.
    Got a new one from Autobarn for $30, drop your coolant, replace tap, replace coolant, job done.
    Took about an hour cos the tap was a bit of a bugger to get out.
    Oh dont forget to bleed the system after replacing coolant!
    Jarrad.
    Its faster to drive very slowly than walk very quickly so hang onto your license and drive like a grandma for a year.
    Now you see me... Now you don't
  1. ve series 2 ute leaking water
    By chad1989 in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-02-2012, 06:02 AM
  2. water leaking from around the water pump
    By justice4all3000 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-10-2011, 08:48 PM
  3. Water leaking in!
    By GIMPY1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-03-2011, 10:52 AM
  4. vrvs sedan water found in boot how i tested to find where the water was leaking from
    By peter1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2011, 08:49 PM
  5. VX leaking water but water tep guage shows normal ???
    By FIN990 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-11-2009, 12:51 PM
