Results 1 to 14 of 14
Thread: coolant leaking still?
    Holden vt calais 5 litre
    Nov 2007
    Default coolant leaking still?
    had a leaking water pump 2 weeks ago so i drained the coolant a replaced the pump and the seal filled the car with coolant drove it for 20 min, topped up the coolant then drove for another 30min with the level not changing. Just checked the level today and the coolant reservoir was very low is this normal after replacing the pump and changing the coolant or do i have a leak still?
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Maybe an air lock????
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
    VX L67 S
    Oct 2011
    Did you use sealant and do the bolts up to spec and also allowing the silicone to cure?
    Do you have a intake manifold leak by chance,the drivers side is usually first to go.
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    Nov 2007
    I did use sealant and gave it an hour and a bit to set I didn't use a torque wrench though. I paid my mechanic top dollar to replace the inlet manifold seal about 2 months ago so i doubt that's leaking I will probably get it pressure tested tomorrow
    som
    som is offline
    vt executive
    Apr 2011
    thorneside qld
    When the engine is cold it should only just register on the coolant dip stick.But air locks can be a bit of a pain to clear.I always run my engine till warm,turn the heater on full and then carefully remove the radiator cap whilst the engine is still running and slowly top up with coolant.Good luck.
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    Nov 2007
    had to top it up again today with about half a litre this must be one huge air bubble!
    Sep 2005
    Nov 2007
    pressure tested it at 18 psi today with no leaks so yeah must of been an air lock, I was told by the mechanic to leave the radiator cap off over night to get all the air out
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Dont know if the 5L is the same ( probably not ) but with my ls1 i just run the car for a couple of mins with the cap off. as the coolant bottle is the highest point.
    som
    som is offline
    vt executive
    Apr 2011
    thorneside qld
    Remember to have the heater on to ensure there is no air in your heater hoses.
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Oh, yeah that to ^^^^
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    The Holden V8 automatically purges any air out of the cooling system in a couple of days after replacing the water pump/coolant. When you replace the water pump/coolant you need to have the heater set to high, turn the engine on with the radiator cap off and top up the coolant in the radiator until the bubbles stop and the radiator begins to overflow. Then replace the radiator cap and top up the coolant in the overflow to the high mark. Over the next couple of days you will have to top up the overflow tank as the air is automatically bled out of the system. Don't take any notice of advice from V6 people as the V8 cooling system design and its requirements are different to the V6.
    If you are still having problems with coolant usage, make sure that the heater hose clamps on the water pump are done up really tight as this is a common place for leaks after replacing the water pump.
  1. Coolant Leaking?
    By dobes in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-03-2011, 09:13 AM
  2. Help! Coolant leaking from my vt!!!!!!!!!!!!!!!!!!!!
    By Miss_KylieC in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-10-2010, 09:58 PM
  3. VZ SV6 Leaking coolant
    By 1FATVZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-09-2010, 09:58 PM
  4. vs leaking coolant
    By reggie_c2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-12-2009, 04:30 PM
  5. VS leaking coolant...
    By leelee in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-07-2009, 05:03 PM
