ok firstly
1) i have some backlash in my diff...at first i thought it was my unis checked em over they are fine...i have narrowed it to gearbox or diff but everything pointing to diff from what i know if i accelerate and back off before it changes there will be a slight clunk at the rear end of the car it DOSNT happen every time only sometimes so i want to know if there is a way to fix that without having to get a new diff,and if a new diff is the ONLY thing what are they worth roughly?
2) i herd about some stuff you can put into your petrol that cleans/helps clean the injectors is this true?dose it work?whats it called
Thanks
not LSD only pulls a pegger xD
No idea with cost but unless you drive like a tool it can go like that for many years without blowing. Unless it whines more than your Mrs with a maxed out credit card I wouldn't bother with it.
Wynns Injector clean. Works ok but if you fill up with premium unleaded each fill it pretty much does the same thing. Maybe a bottle then premium???2) i herd about some stuff you can put into your petrol that cleans/helps clean the injectors is this true?dose it work?whats it called
Reaper
yep oright yeh no whine or anything outrageous just yet shes got 270 on the clock so i baby it around atm
ALWAYS use 98/95 premium oright well ill give it a shot and see if it makes a difference over time or not
Cheers mate
Whats the condition of the diff bush?
Oil change perhaps? When was the last one done?
