Results 1 to 2 of 2
Thread: someone help me locate something
    vt ss
    Mar 2011
    sydney
    Default someone help me locate something
    ok so i have a problem with my vents the air will only come out at the demist, and when u turn the dial there is nothing.
    now i have looked for the control module which controls the vent selection which is suppose to be situated underneath the brake reservoir, and here is where the problem is, there is absolutely nothing there but bare body, any idea where it could have been moved to or where else it could be located?
    its in a vt ss, series 1, 5.0L
    thanks heaps
    chris
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Here is a thread that was from today as well that might help, so maybe a search would have found it. There is nothing under the brake reservoir to do with the air conditioning. The vent selector switch (dial) controls the vents in standard A/C (not climate control) If you have climate control then there is a vacuum solenoid pack which is located on the lower rear of blower motor housing.
    Aircon Will Only Demist????
    MY RIDE
  1. need to locate lighter fuse for vt
    By fergie_vs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-04-2010, 01:44 PM
  2. [b][/b] locate & change manual trans fluid vs
    By mathew_mg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2010, 10:21 PM
  3. Locate my MAP sensor
    By Zipster in forum Electrical Wiring / Questions
    Last Post: 08-12-2008, 06:42 PM
  4. where can i locate the fuel pump and filter on my vp?
    By zumanity in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-03-2007, 06:24 PM
  5. How to locate a fuel line?
    By luckye in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-03-2006, 09:50 PM
