hi
1999 vt V6 ,
have replaced CAS two weeks ago , stalling problem (when HOT) still there, are there any other areas to check????
any help would be great
thanks
Have you done an error code check? Also, the bridging of the pins will only bring up current codes, you will need a scan tool to check for older stored codes.
Take the connector off the DFI module and clean every pin spotless.
thanks guys
error code shows CAM Sensor ??????
Have you tried changing the cam angle sensor???, that is where i would strat.
Take it easy...But do take it...
Do not argue with an IDIOT.
He will just drag you down to his level an beat you with experience.
Some people take me the wrong way, Like smacking up Marijunna.
ordered a CAM sensor $85 and will change on saturday hopefully this will do the trick, keep you posted.
