Results 1 to 12 of 12
Thread: Ecotec Information
    Hilux 3.8ecotech
    Oct 2011
    Cool Ecotec Information
    Hey All,
    Just after any help i can get with this issue, i currently have the ecotec 3.8vt engine conversion in my Hilux ln106r 4x4, i am only getting about 200kms per tank, i have read on previous posts things that can cause this issue and so far i have changed:
    plugs and leads
    Oxy sensors (which fixed the stalling issue i had)
    cleaned airflow sensor
    polished inlet manifold and throttle body
    are there any other components i should be looking at in order to increase my fuel economy, im driving it round town and changing gears at 3000rpm not planting my foot.
    the engine seems to be good plenty of power, only 120,000kms on the engine, although i am running 33" tyres which will decrease the fuel economy but not to that extent.
    Appreciate any help
    VX Commodore Executive
    Jun 2011
    Central Coast
    What size tank?
    Pretty good economy from a 20 lt tank, pretty bad from an 80 lt tank.
    Would be more helpful if you gave lt per 100 kms (or even kms per lt).
    Cheers.
    Hilux 3.8ecotech
    Oct 2011
    its a 65L tank
    Kilometres driven: 250 Km
    Litres of Fuel used over distance travelled: 65L
    Consumption in Litres per 100 Kilometres: 26 L/100Km
    Consumption in Kilometres per Litre: 3.85 Km/L
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    Hmm, what kind of driving are you doing? City?
    Cause I get around 12L/100km. Mixed. I get about 15L/100km in the city, bit over that with the air con on.
    Add to that shifting at 3000rpm you said, plus you're raised high enough to drive over my car. I don't know I think you'd be just about there.
    I go for a trip to the beach or something, drive a few hundred kms on the freeway, see if your fuel economy picks up at all, if not - then you've got a problem somewhere.
    EDIT: What fuel are you running in it? Maybe it would be worth tuning it again.
    The New Ride - The Class 2 Shuttle Craft (VE)
    I'll be he comes to get you, some shopping trolley kind of thing, that gets you where your going nice and slow... Well off you go that's fine, the pleasure's all mine.
    When I light the nitro on my HQ 454 Monroe!
    VP Wagon
    Mar 2009
    vx s pack II
    Jan 2010
    aLKIDA
    Check the sender unit in the tank.
    Do you run the tank empty not that any one should and get 200k.
    VT Calais
    Mar 2009
    SA - Victor Harbor
    not sure if this helps at all but my brother inlaw has a prado with the same tyres you have on he gets 24L per 100km/h, been everywhere to have it serviced, everyone said it was the tyres, put stock ones on for shits and giggles to see and got better milage
    VY SS
    May 2011
    Auckland
    Is your odo calibrated to that size wheel? If the wheels bigger than its calibrated to you'll be going further than the odo says.
    What Rpm are you doing at 100k? Even my vs ecotec was doing under 2 at 100k
    Mar 2004
    Yeah check your speedo accuracy, compare it to a GPS or an iphone/smartphone.
    I have heard that most 4x4 conversions, while they give you more power, they end up as fuel gobblers because the diff ratios are wrong for the lower reving V6/V8 etc.
    As mentioned by m1lky, an ecotec is usually 2000 rpm at 100kmh, wheras the original 4 would be doing quite a bit more.
    Hilux 3.8ecotech
    Oct 2011
    Cheers for all the replies, i have changed the tyres over to standard size and i get about 20kms extra, im driving all round, freeway driving i can get about 300kms to a tank, to work and back i get about 250, 270 with standard tyres.
    At 100kms my revs are about 2900 with my diff gears, so it is a lot higher then normal,but i thought i would get a bit more then this ?
    may have to get a tune, my speedo is out with running the 33" tyres so this is also i factor in terms of the KMS the odometer is recording which i will fix. But even with the correct tyres the odometer is recording about 20kms extra.
    thanks guys
    btw anyone know a good place in melbourne for tunning?
    MikeCuzzy's Avatar
    Jan 2010
    Wollondilly, NSW
    At 3000ish rpm, the Ecotec is chugging petrol, thats right around peak torque too.
    Get it all tuned and reset, but in reality, there's a reason big cars like that run on diesel fuel. You're gonna get extra performance in the V6 as you've probably noticed, but fuel will cost you.
    Hilux 3.8ecotech
    Oct 2011
    Thanks all, we will see what a good tune does to it, if anything.
  1. Any Information on rebuild ecotec, Cam/Heads/Manifold.
    By uNEEk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-11-2010, 11:25 PM
  2. VX V6 GTX Information
    By stainer in forum General
    Last Post: 19-10-2010, 01:25 PM
  3. would like some information
    By spice_man2069 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-05-2006, 11:32 PM
  4. Vy Information
    By Jaime S. in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-02-2004, 09:04 PM
Tags for this Thread
