Results 1 to 4 of 4
Thread: Vt code check problem?
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Default Vt code check problem?
    I'm on my phone and I had a look at the codes on the forum but I doesn't come up with them all and can't tell if it's my phone not loading properly or the page is no good, can someone help with these codes please
    35, 44, 45, 48, 57, 65, 76, 92.
    Cheers Pat.
    vs commodore
    Oct 2009
    Tamworth NSW
    Code 35 is idle speed error (IAC unable to control idle speed).
    Code 44 is RH oxygen sensor (signal lean).
    Code 45 is RH oxygen sensor (signal rich).
    code 48 is cam angle sensor (no signal).
    code 57 is injector power supply monitor, voltage variation at ECU terminal A4.
    code 65 is LH oxygen sensor (signal rich).
    code 76 is air/fuel ratio,(variation between left and right banks).
    code 92 is low speed cooling fan fault.
    Id first up clear these codes by removing the negative battery terminal for a minute or two, and then recheck the codes again, just to make sure they have cleared properly, and that you only get code 12 showing up. Then after the car has been started or driven again, recheck the codes again to see if any have returned, because sometimes codes can set from a "one off glitch" in the system, so clear them firstly and see if they return .Then go from there.
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Quote Originally Posted by pjdm1980 View Post
    Cheers Pat.
    12 Normal Operation (System Pass)
    13 Oxygen Sensor (O2) or Circuit
    14 Coolant Temperature Sensor – Voltage Too Low
    15 Coolant Temperature Sensor – Voltage Too High
    16 Coolant Temperature Sensor – Voltage Unstable
    17 PCM Coolant Temperature Circuit
    18 n/a
    19 Throttle Position Sensor
    20 n/a
    21 As above – Voltage Too High
    22 As above – Voltage Too Low
    23 MAS (Manifold Air Temperature) Sensor or Circuit – Voltage Too Hig
    24 Vehicle Speed Sensor or Circuit
    25 MAS (Manifold Air Temperature) Sensor or Circuit – Voltage Too Low
    26 MAS (Manifold Air Temperature) Sensor or Circuit – Voltage Unstable
    27 n/a
    28 Transmission problem (get wallet out, yippee heaps of money
    29 n/a
    30 n/a
    31 Theft Deterrent System – Missing Signal
    32 MAF (Manifold Airflow) Sensor or Circuit
    33 MAP (Manifold Absolute Pressure) Sensor or Circuit – Voltage Too Hig
    34 As Above – Voltage Too Low
    35 Idle Speed Error
    36 Vacuum Leak
    37 n/a
    38 n/a
    39 n/a
    40 n/a
    41 Crank Angle Sensor
    42 EST (Electronic Start Timing) Circuit
    43 Knock Sensor Circuit
    44 O2 (Oxygen) Sensor – Lean
    45 O2 (Oxygen) Sensor – Rich
    46 No Reference Signal From Ignition Module While Cranking
    47 No 18x Reference Signal From Ignition Module
    48 Camshaft Position Signal Missing
    49 Camshaft / Crank Signal Intermittent
    51 MEMCAL PROM Error - Check insertion of MEMCAL in socket and bent pins.
    52 CALPAK Error - Check that CALPAK is in place, fully inserted, and no bent pins.
    53 System Over-voltage - Car's alternator has produced >17.1 volts for over 2 seconds. Check charging system
    55 ECM A to D Error - Check ECM grounds, or excessive input voltage
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Thanks for the guys, really appreciate it.
  1. how come thermo fan comes on when i do a sensor code check
    By vl rb30 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-03-2011, 04:02 PM
  2. I did an Error Code check and got a few codes, so what do I need to replace?
    By hsv91ss in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-11-2010, 07:53 PM
  3. how do you check your paint code????
    By adamrollo9 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-03-2010, 07:18 PM
  4. How do i perform an error code check?
    By vs_commy5506 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-06-2009, 04:26 PM
  5. Fault code check on a Vectra
    By mouce in forum General
    Last Post: 26-05-2009, 09:14 PM
