Results 1 to 5 of 5
Thread: Vt l67 top end rattle
    Vt spac twincharged
    Oct 2011
    Portland
    Default Vt l67 top end rattle
    Hi!
    Iv got a supercharged v6 with a cam and 120 pound springs and I'm getting a rattle sound coming from the top end area. The motors done 200,000 but has had bottom end rebuilt under warranty. It rattles under no load revving ie. Revving up to 2000, 3000 revs in neutral and when I'm driving in a low gear with it at 3000 revs no load. It's a ticking sound like really bad lifters. Or could be balance shaft bearings from what iv researched. Any help would be appreciated!
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    have you changed the oil recently - if you haven't I would suggest it!
    Maybe try a bottle of lifter free or similair
    vr wagon
    Aug 2010
    vic
    I'd go on l67torque and have a search around there. If you can't find your problem on search ask the guys in there.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Sounds like the super charger might be your problem, I've heard some of the coupling gear in the blower snout wear out and can make this kind of noise-
    Vs supercharged 6 makeing noise at front of supercharger near belt ideas whatswrong??
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Its likely to be your coupling gear which it the connection between the snout drive shaft and the rotor gears. They're made of a hard plastic/composite material and with age/use slowly wear and develop the rattle you've described. Its a 30 minute job to replace it with a new one.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
  1. rattle
    By impulsed_sv6 in forum Car Audio
    Last Post: 16-11-2010, 08:27 PM
  2. The Rattle !!
    By BOY1236 in forum VE Holden Commodore (2006 - ?)
    Last Post: 01-09-2008, 12:06 PM
  3. Got a Rattle???
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-01-2007, 01:46 PM
  4. I have a rattle too :(
    By Apoc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-07-2006, 11:22 PM
  5. Door Rattle - Yes the Rattle that hunts Holdens
    By Ratty in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-05-2006, 09:01 PM
