Results 1 to 2 of 2
Thread: Oil Leak, help.
    '97 VT Calais
    Apr 2007
    Default Oil Leak, help.
    Lets brainstorm my oil leak please.
    So i finally got around to having my inlet manifold gasket replaced by a mechanic.
    He didn't tighten the negative battery terminal up properly which caused a short term problem, but now it seems i have a bigger one.
    A massive oil leak, followed by a 'tractor' sound coming from the passenger side of the engine block.
    The car is leaking on top of the sump area. Not noticably above that. It appears to be oily around the return lines on the drivers side under and around the filter but also on the passenger side as well.
    Given i have shot engine mounts too, is it possible that the engine shake on the cross member* has caused the sump damage and that's the problem? I can't get my head in to look that far. Plus the noise possibly
    Any idea?
    DavidPartay's Avatar
    DavidPartay is offline somewhat awesome
    02 VX Exec wagon
    Feb 2004
    Central Coast, NSW
    Sorry to bump such an old thread, but I'm wondering if you found out the answer to this?
  1. oil leak
    By pac3y in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-04-2009, 01:24 PM
  2. Vr Oil Leak
    By Vr929 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-01-2009, 04:38 PM
  3. about that oil leak..
    By aella in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-12-2008, 09:00 PM
  4. Oil Leak..
    By hN! in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-11-2008, 08:07 PM
  5. Oil leak
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-08-2006, 10:37 PM
