Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Reaper
Thread: No thermostat LS1
    VN commodore S1 & VXII Berlina LS1
    Jan 2009
    Default No thermostat LS1
    Doing a coolant flush and found the thermostat has been removed.
    Haven't had a problem as yet with it out, should it be something to replace asap or put on the general to do list?
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Engines perform best from both a wear, power and economic point of view at their normal operating temperature therefore it is in your interest to fit a thermostat ASAP. To delay will cause more engine wear as it takes a longer time to warm up if it even gets to peak temp at all on a cold day.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    Jan 2009
    Ok will do that asap.
    Put new coolant in, ran till fans came on at 99 temp drop to 93-94 fans turned off, but the level in the reservoir didn't need topping up...this normal ?
    VX Calais LS1, VS Calais L36
    Mar 2010
    Fan temps sound about right to me. I don't think the LS1 thermostat even opens until about 91 degrees.
  1. Thermostat
    By Rolla_Rolla' in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-12-2009, 01:27 AM
  2. Which way does the thermostat go? + highflow thermostat?
    By thek in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2009, 11:11 AM
  3. thermostat
    By TheyDontWantMusic in forum VL Holden Commodore (1986 - 1988)
    Last Post: 16-12-2008, 02:19 PM
  4. thermostat
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2007, 06:58 AM
  5. thermostat
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-12-2006, 01:14 AM
