Hey guys really need help, changed my headlight bulbs yesterday plugged them back in fine but I did need to push the battery aside to get the the drivers side headlight. The lights worked fine but then I realized my brake light and indicators were gone I had a look in the cabin fuse box they were gone so I replaced them and they blew again I had an racv have a quick look at all the wiring around the headlights and he said it's all connected fine. So is it a matter of to much current running through or what? Also when I turned the car on the first two times after replacing the bulbs it did quite a loud shudder need help as I'm not very good with cars. Thanks
Few things, did you put the battery back properly? There's no chance is touching the metal of the car?
Did you put the correct bulbs in place? Have you touched any other electrics in the car? I once rigged up the stereo, and didn't insulate a wire properly and it made my interior lights short.
Also when you were changing the bulbs, did you disconnect the negative battery terminal?
Mike.
The New Ride - The Class 2 Shuttle Craft (VE)
I'll be he comes to get you, some shopping trolley kind of thing, that gets you where your going nice and slow... Well off you go that's fine, the pleasure's all mine.
When I light the nitro on my HQ 454 Monroe!
Not sure about the battery I'll check it when I get home but it looks like it's all sitting normally, and yeah I put the bulbs in correctly but no I didn't disconnect the negative terminal should I have?
Well Vt/Vx electrics are VERY twitchy, I make sure whenever I mess with anything I disconnect the negative terminal, mostly because I blew bulbs and fuses if I didn't.
Well assuming the battery checks out, my best bet would be a wire shorting out somewhere somehow, wrong bulbs, or there was a power spike cause that battery was still connected.
I would suggest taking off the negative terminal, change the troublesome fuses, and then connect battery back up. See if they blow, if so, I would say there is a fault.
Yes, you should always disconnect the battery when doing anything with electrics in a car.
Take it easy...But do take it...
Do not argue with an IDIOT.
He will just drag you down to his level an beat you with experience.
Some people take me the wrong way, Like smacking up Marijunna.
Ok illtry that and see how it goes thanks
Didn't work
So just to clarify mate,
* Your headlights work.
* Your tail lights and indicators do not (the fuses for them are blown).
* The battery is not contacting the car at any point.
* When you changed the light bulbs over, you at no point touched any of the cars wiring.
If this is the case mate, I would suggest going to auto electrician, perhaps they can sort out the problem - as it seems it's not the usual suspects.
what wattage globes did you put in?
if your tail-lights are blowing over and over, and its a series 1 - look at the rear section loom of the car... unfortunately this was a notorious problem with some of the series ones (the rear loom degrades and ark's out in weird n wonderful places).
every time ive dealt with this for friends, we just pilfered a rear loom from a vx or a series 2 VT
94 VR V6 - No ABS & NO IRS... a true mans steed and a 99 VT XU8 for good measure.
Check you didn't accidentally pinch the wires in-between the bulb and the bulbs seat.
I have a similar prob with my SII SS after changing bulbs the LH headlight fuse goes out and the fog lights (fully) and high beams (dull) turn on by themselves and sometimes stay on even with the key out. so will try some of the suggetions above.
sounds loke you either fitted incorrect globes or have a short somewhere
is that all you did, change headlamp globes?
do you think the brake and idicators worked prior to you changing headlamps
if they did always start at the last thing you did when a situation like this occurs
no need to dis-connect battery to change globes, they should not be powered up
indicator and brakes are on different fuses, which fuse blew or both
the shudder sounds like alternator trying to make up for a huge voltage drop aka short circuit
