Results 1 to 4 of 4
Thread: re calibrating fuel gage
    vt executive
    Oct 2011
    leppington nsw
    Default re calibrating fuel gage
    hi guys
    had my fuel pump replaced but now my fuel gage is out of wack when i fill it up it says its a 1/4 under on the gage
    when my warning light comes on at 65 litres left i still get about 150 km out of it how can i fix this
    VX 'S' S1
    Apr 2005
    South East,Victoria
    When i replaced mine i had to adjust the float level. The bottom of the float should be 20 mm higher than the bottom of the fuel pump .Just put it on a flat surface and bend the float lever to suit . mine was 10 mm under and i had similar troubles after replacing my pump.
    BarossaVT's Avatar
    BarossaVT is offline VT L67 214rwkw
    VT S L67
    Jan 2007
    Sth Aust
    Yeah if they bent the float arm it will affect the fuel gage.. It might depend on the model but on the VT the distance between the bottom of the float and the flat surface/bench I thought should be 10mm.
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Quote Originally Posted by BarossaVT View Post
    Sorry my bad , i should have read mine was 20mm and the proper distance should be 10mm
  1. calibrating fuel & gauge!
    By andrew_oc42 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-12-2010, 04:51 PM
  2. 'fuel gage error' displayed, ute wont start
    By mickey007 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-10-2010, 05:04 PM
  3. fuel light and gage
    By monza 340 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2010, 04:30 PM
  4. vr commodore fuel gage
    By lukedunshea in forum Electrical Wiring / Questions
    Last Post: 03-09-2009, 11:41 AM
  5. sticking fuel gage/leaking bootlid
    By smc69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2009, 05:47 PM
