Results 1 to 4 of 4
Thread: vx stuttering
    vx wagon
    Nov 2011
    adelaide
    Default vx stuttering
    I've got a vx wagon, after changing the spark plugs, it started stuttering while driving. Thought it was the trans, bought another trans, changed it but the stuttering is still there. Temp gets to about half, and it stutterrs around 60km, more so when its in the first drive (overdrive). Tested some of the leads, one was a bit faulty,changed it, but it's still doing it!!! It's got me stuffed.
    Any help would be greatly appriciated
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Probably a faulty lead, you should have bought a new set, much cheaper than a transmission. If it is not the leads then it could be a faulty coil or fuel injector but when ever mine starts missing it's always been a faulty lead. The fact that the problem started after changing the spark plugs would tend to indicated that you might have damaged a lead when removing them or you cracked a spark plug.
    MY RIDE
    VT 2
    Nov 2008
    Check Leads and plugs.
    Check Coil Packs.
    Check Connection to the Ignition control module another the coil packs.
    It will an electrical fault, in the ignition system, not anywthing else.
    vr wagon
    Aug 2010
    vic
    Check your plugs, you might have cracked one putting them in, check leads are in right firing order. If not it's coil pack.
  1. VX SS stuttering
    By Nix79 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-07-2011, 07:37 PM
  2. stuttering
    By zapper in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-04-2010, 07:31 PM
  3. Car stuttering forwards
    By Kurtp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-02-2010, 10:30 AM
  4. stuttering problem~!
    By belave in forum Jokes/Humour
    Last Post: 25-04-2007, 01:01 AM
  5. stuttering cat
    By bazcom in forum Jokes/Humour
    Last Post: 09-11-2006, 12:24 PM
Tags for this Thread
