Results 1 to 2 of 2
Thread: What does code 57 mean?
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Default What does code 57 mean?
    What does this mean-
    code 57 is injector power supply monitor, voltage variation at ECU terminal A4.
    Cheers Pat
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    My manual only shows DTC57 applying to Holden V8 engine with auto trans - is that correct for your car? Not sure why this is so I would have thought it applied to manuals as well. The description is:
    The injector voltage monitor line is used so that the PCM will know the exact voltage the fuel injectors are operating at. This voltage is used to control the pulse width modulation of the fuel injectors. If the injector voltage monitor line drops more than 2.5 volts for more than 5 seconds, Diagnostic Trouble Code (DTC) 57 will set. This DTC will turn ON the Check Powertrain lamp, and will have a DTC set in the PCM......
    You need to check the PCM connections for proper mating - C15 and C16 are for injector control and D7 is for the injector voltage monitor line. Don't know where you got terminal A4 from.
  1. error code 12, 3 times then code 76
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2010, 06:36 PM
  2. Code 83
    By Kurtp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-07-2010, 10:06 PM
  3. Code 72 - Vehicle Speed Sensor (VSS) and Code 73 - Pressure Control Solenoid Current
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2009, 04:39 PM
  4. Code 45,,help~~
    By protossw in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2006, 01:27 PM
  5. Code 14 what the hell is error code 14!@*&%#
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2005, 12:35 PM
