Results 1 to 14 of 14
Thread: Still Overheating - 2001 VX
    2001 VX Commodore
    Oct 2011
    Gold Coast
    Default Still Overheating - 2001 VX
    I've just completed doing the system flush as per How To Flush A V6 Cooling System, but for some reason now the car overheats faster, and even more so than before I started the job...
    Have I possibly done something wrong, or has doing it caused another problem like water pump going bad ???
    Any advise welcome people..
    Tim Smtih's Avatar
    Tim Smtih is offline Sexy Man
    VXS1 Acclaim Family spec Limited Hardcore Edition
    Sep 2009
    Here.
    Sorry i didn't read the how to, but did it mention replacing the thermostat? Also, did you bleed the system after refilling with coolant/water/corrosion inhibitor?
    http://tinyurl.com/MetalisAwesome
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
    Albert Einstein
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    did you reverse flush the rad. out of the car? if so did you plug in the thermo
    2001 VX Commodore
    Oct 2011
    Gold Coast
    Yeah guys, have done both of those things..reverse flush etc, used flush / cleaner solution...and bled the system. On the bleeding system part, is it possible I didn't bleed it enough ??
    VX SS
    Jun 2005
    2001 VX Commodore
    Oct 2011
    Gold Coast
    2001 VX Commodore
    Oct 2011
    Gold Coast
    From what I can tell, everything is running normally..fan cutting in, plenty of fluid etc..Another thought, is there a possibility there a problem with the sensor, or is that stretching it a little ?
    VX Exec 01
    Aug 2008
    Melbourne, Vic
    Quote Originally Posted by Just_Me View Post
    Wouldn't be the first time this has happened, I'd be looking at that if you can't see any leaks or anything, the next i'd be looking at the water pump.
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    if the gauge tells you its hot, and the engine is still normal then there's a chance its a faulty temp sensor.
    if your not losing coolant, then id look into a small leak in your water pump, or a blocked radiator.
    Starin at the world through my rearview
    Go on baby scream to God, he can't hear you
    I can feel your heart beatin fast cause it's time to die
    Gettin high, watchin time fly
    2001 VX Commodore
    Oct 2011
    Gold Coast
    Thanks for this last reply, based on that...the sensor itself is placed where ? I think I've got to start looking at eliminating things and just work my way through. And the senor is probably the cheapest & easiest place to begin. Additional to this, I will also bleed it abit more just incase there is air still in the system, and check again for any leaks. Is the following what i need to be looking for ?
    COOLANT TEMP SENSOR TRIDON COMMODORE ECOTEC VS VT VX VY | eBay
    Killr6's Avatar
    XR6T
    Sep 2010
    Hervey Bay QLD
    yeah and your sensor is just underneath your thermostat housing, they are easy to replace, well kinda like to the right off it abit but under it lol.
    have you replaced your radiator cap, that could be faulty letting air in the system also.
    and your thermostat have you replaced that? might not be opening fully. id replace these two things before the temp sensor.
    they are both cheap things to look into.
    2001 VX Commodore
    Oct 2011
    Gold Coast
    Thanks 'DanLucas",
    Yeah replaced both thermostat & radiator cap yesterday when i did system flush etc, along with the coolant stuff so trying to eliminate the easy things 1st, before doing water pump / radiator. And like i commented on earlier also, going to re-bleed as well encase there air still in system. Infact, on that matter is there anyway of exactly telling if all the air is out / or how long i should let spray pass through nipple ?
    Killr6's Avatar
    XR6T
    Sep 2010
    Hervey Bay QLD
    when you bleed it you should open and close the theromstat housing a couple of times to get all the air out.
    Killr6's Avatar
    XR6T
    Sep 2010
    Hervey Bay QLD
    you can pick up a radiator for like 100$ and a pump for about 40$ off ebay. should be fine.
  1. vx 2001
    By jenny kay in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-05-2011, 11:43 AM
  2. My 2001 vx ss
    By ss~skills in forum VT - VX - VU - WH - V2
    Last Post: 31-08-2010, 10:13 PM
  3. Hi all, im from the UK and this is my 2001 HSV GTS-UK
    By kamylion in forum VT - VX - VU - WH - V2
    Last Post: 18-02-2010, 02:29 AM
  4. [NSW] F.S. 2001 hsv xu6 #65
    By mjd1810 in forum Vehicles For Sale
    Last Post: 04-09-2009, 08:14 PM
  5. Vx S 2001
    By webwombat in forum VT - VX - VU - WH - V2
    Last Post: 13-04-2006, 06:55 PM
