Hey fellas I'm having trouble with a vt v6 wen it starts it runs really rough and then stalls and also stalls wen the accelerator is pressed as if it's starving for fuel or air I changed the fuel filter on it cos it had
Been run low on fuel I also hav checked the error codes and it says it's fine any help would be greatly
Appreciated as it's stuck at the servo
Cheers launer
Did you put enough fuel in? when they run out of fuel $5 or $10 may not be enough to get it going again.
MY RIDE
Petrol/Coil packs.Fuel pump and crank angle sensors are the most common problems.
Originally Posted by 87RB30VL
Huh? I got given the gun of my neighbour,
Cool cheers guys Yea put enough fuel in it's got half a tank lol if it was the crank angle wouldn't that bring up a fault
Code
