Results 1 to 7 of 7
Thread: VX II on LPG - now Check Engine light comes on
    VX Commodore Executive
    Jun 2011
    Central Coast
    Default VX II on LPG - now Check Engine light comes on
    We recently had the waggon converted to LPG.
    Now the Check Engine light comes on sometimes, stays on for a couple of minutes, then goes off again.
    Any ideas what may cause this?
    Everything else appears normal.
    Cheers,
    JG
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by jughead1 View Post
    Cheers,
    JG
    You need to check the fault codes to point you in the right direction.
    MY RIDE
    Jun 2011
    Central Coast
    That much I knew.
    But how to check fault codes?
    I have a OBD cable to fit, and I have a lap top, but I need some software to actually read the codes. Any suggestions? (preferably software I can download from the internet).
    Cheers,
    JG
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    That much I knew.
    JG
    I don't know what you know or don't know, I can only go by what you've written and you didn't ask how to read the codes. You can check your codes without any laptops or software. Do a search on how to read fault codes. Just type in fault codes and you should find something. I've posted it many times but can't be bothered finding it again.
    MY RIDE
    Jun 2011
    Central Coast
    Sorry, that comment of mine was not ment to be scartastic.
    Thanks for the advice. (Again, not being scartastic.)
    Cheeers.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Cheeers.
    No problem, it's hard to tell how things are intended when they are written.
    MY RIDE
    Jun 2011
    Central Coast
    This morning, the car started stalling and making a crackling noise (as reported by my wife - I am deaf, so couldn't hear anything)while running on LPG.
    So I switched to petrol (on my way to work), and it is idling very high - around 1,200 RPM (in drive while stopped at the lights).
    As I was running late for work, I have not had a chance to have a look at the engine bay, but it sounds like a loose connection somewhere.
    Anybody experienced with LPG who could point out where to look?
    (And I have not had a chance to look at the error codes as yet).
    Cheers.
    JG
  1. engine check light came on then went off??
    By cxcxcxvcvcvc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-07-2011, 11:02 PM
  2. Check engine light
    By garryv in forum General
    Last Post: 16-07-2011, 10:58 PM
  3. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  4. Check engine light MW
    By gavoon in forum VE Holden Commodore (2006 - ?)
    Last Post: 08-01-2011, 02:44 AM
  5. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
