Results 1 to 2 of 2
Thread: VT abs Module
    2003 VY Calais SII Supercharged
    Jan 2011
    Pakenham
    Default VT abs Module
    Hey Guys you may or may not know but there are 2 different types of abs modules you have the smaller 6 pin or the bigger 10 pin always double check before you purchase, unlike me i never checked bought the dam thing and it was the wrong one =(.
    Also incase anyone needs to know its very easy to take off and install.
    You'll need a star screw driver to take off the 6 screws and a 13mm spanner to loosen the bolts holding the unit together (Trust me it will help you with the bottom 2 screws)and a flat head to undo the plug that is connected to the bottom of the module.
    Step1.
    Pull off the red or black plug at the front of the module if you cant pull it off with your finger put a flat head in the space and lever it very gently until you can move it freely,Use your 13mm spanner loosen the 2 bolts on either side of the abs unit so you can raise it slightly, then disconnect the bottom plug as well (there is a small clip on the bottom left hand corner holding this in just undo that and use your flat head to get it off gently)
    Step 2.
    Simple unscrew all the star screws ( technical term is torq screws i think)
    Step 3. remove the abs module
    step 4. Insert the new abs module and repeat step 1 in reverse screw the thing back up tighten bolts and away you go
    Jan 2011
    Pakenham
    I now have a spare 6 pin abs module if anyone needs it let me know i also have a set of new ball joints, a overflow bottle, a set of 17inch rims 2 damaged and soon a supercharger PM me for a price if you want any
  1. interchaning Vy s1 berlina climate control panel/module with VZ module
    By mudmutt in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-04-2010, 02:54 PM
  2. FS [VIC]: power arial module and centrol locking module
    By georgeonboost in forum Parts And Other Items For Sale
    Last Post: 24-09-2008, 06:41 PM
  3. module
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2006, 08:16 PM
  4. Dfi Module
    By brad_m_is in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-11-2005, 05:14 PM
