Results 1 to 10 of 10
Thread: What is this pully for? Vt v6
    VT S2 Wagon
    Nov 2011
    SA
    Default What is this pully for? Vt v6
    What is the pully on the bottom right of the water pump for ? The smooth one. When I took it off the little collar bit of alloy that the bearing goes on and the bolt goes through sheared off . How can I fix this so the pulley can go back On
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It is an idler pulley, it doesn't do anything except keep the belt away from other pulleys. Can you post a pic of the problem so we can understand it better.
    MY RIDE
    '97 VT Calais
    Apr 2007
    You will need to replace the whole pylon.
    There are 3 bolts to undo and straight swap.
    VT S2 Wagon
    Nov 2011
    SA
    I'm at work so can't post a pic but pretty much what holds the pully in line has sheared off. So it is a replaceable part then ? Will one from either a vr or vp work ? Will I need a new gasket too ?
    VT S2 Wagon
    Nov 2011
    SA
    Heres some pics guys. Just need to know what the part that it mounts onto is called. If i need to order one or if another model car has the same one cheers.
    Sorry not focused properly.
    98 vt s pac
    Feb 2009
    Corowa NSW
    lol i've snapped a couple of them over the years when i was replacing the pullies, they get pretty brittle...... you can pick them up at the wreckers for about $10 VT and VS have the same part, from memory theres an earth wire you need to remember to put under the nut when putting it all back together
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    They're about $30 new from Holden. Worth the extra $20ish to have a new item imo
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    VT S2 Wagon
    Nov 2011
    SA
    how do i get this thing off? its hard to see without taking the radiator out lol..
    I dont have a wreckers anywhere near me i live in the country.
    Whats the part called and does anyone on the internet sell them? Cheers
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Bates View Post
    I doubt that you will be able to get one anywhere apart from Holden or a wreckers. No idea what it is called. Use a small mirror to get a look at how it is mounted, probably as stated above, 3 bolts.
    MY RIDE
    VT S2 Wagon
    Nov 2011
    SA
    all good guys got it off after a little bit. sourced a used one from a mate untill i can get a new one here. cheers.
  1. 20% Pully
    By ufo8mycow in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-03-2011, 07:01 PM
  2. what pully have i got
    By motox75 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-07-2010, 07:41 PM
  3. VT pully wheel -how hard do you pull a pully
    By wildwabbit in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-02-2010, 05:24 PM
  4. Replacing SC14 stock pully with an alternator pully ?
    By gemini in forum General Discussion
    Last Post: 08-05-2006, 04:02 PM
  5. A/C pully..
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-03-2006, 12:14 AM
